£6.3k? ****, I was thinking it would be somewhere around the £1.5k-£2k mark.
No idea sorry mate, I don't live in the UK so I did no research there.Richdog do you happen to know which UK clinics are recommended for temples/frontal hair line. I have mentioned in this thread in the past i'm looking to get mine done. For front work Dr Bissanga seems to be recommended but he's in Belgium and i don't fancy flying back and forth should any issues arise.
FUE surgery in London at a good clinic that I just Googled starts at £3.5k for the minimum amount, so likely runs up to £4.5-5k or more! Links https://wimpoleclinic.com/prices-how-much-does-hair-transplant-cost/ and https://www.trustpilot.com/review/wimpoleclinic.com£6.3k? ****, I was thinking it would be somewhere around the £1.5k-£2k mark.
Hi tefal, I agree with your sentiments but this was already discussed and closed many pages ago, with FF's blessing, so lets please not open up that silly debate again, and instead focus on the positives of peoples results so far and helping people that want to get it done.Tbf FF it's easy to say that when you look like you.
I get it with people feeling self conscious over this stuff and like most anxiety it's actually only them that cares most of the time when it's something like hair vs something like a cleft lip where people will stare.
No worries dude, easily done!Oh sorry I opened the thread part way though didn't realise it was about a year ago
Of course it'll look **** in 5 years as you're not (as far as I recall / know) taking a 5-alpha reductase inhibitor and will therefore have a perfect hairline and crown with thinning surrounding patches, but I guess your surgeon knows best.
That would be my concern too with this stuff, I'd be interested if @chipperhead has been recommended to take the tablets or not after his transplant?
I guess IF you're in a position where you're taking the tablets after surgery then I guess the optimal thing to have done would have perhaps been to start the tablets at the first sign of loss. There are presumably some people out there who started taking tablets in their early 20s and have managed to both avoid the hair loss and/or surgery.
Personally, for me, I don't particularly fancy the idea of taking the tablets, there is a well-documented effect on libido for example. I guess though at the point I'm at now I've probably lost most of the hair I'm likely to lose and so would be looking at a more substantial transplant and IIRC the actual transplanted hair itself isn't at risk but rather the existing hair on the top of your head. It certainly seems to be a potential risk if you get a transplant early on, you could sustain further hair loss in other areas still, though I guess the option of further transplants are there too, given you have sufficient donor hair on the back of your head or elsewhere etc..
goes without saying though that both the sets of pictures posted do indeed look great!
A mystical land, hidden in plain sight, that is friends with everyone...Interesting thread, thanks for sharing.
@Richdog, I'm intrigued to know which country you reside in exactly?
I have a good while yet, likely around 10-15 years, until the hair will start to look noticeably thinner in the non-HT areas and if needed I would not hesitate to get surgery again, as time and money are not an issue. I am also not going to go bald everywhere on top (I will follow my fathers genetic pattern, who still has hair in his late 60's with a balding top and crown) so it is not going to need extensive treatment to address that ongoing gradual hair loss vs people who really do go fully bald.
Yeah, I guess taking the tablets perhaps is also dependent on the pattern and how extensive/rapid the baldness it etc... clearly some recommend them and others don't.
I don't know if you can necessarily assume it's going to be the same as your father's though for example my dad has a full head of hair and his dad was maybe a bit thin on top in his 80s but not bald either. It's my mum's dad who was bald.
I'm happy enough with a buzz cut as it still suits me/I've got quite a normal head, decent facial symmetry etc.. had had a buzz cut out of choice/just fancied it for a bit in my early 20s too at one point. I do think I probably looked a bit better with hair though. If I were to have a transplant ans was recommended taking the tablets then it would feel a bit silly/like something I could have pre-empted aged 19 or 20.
I believe that I can indeed reasonably assume that it will be very similar to my father, considering my hair is so far following his baldness pattern (he has checked and confirmed multiple times) and my granddad was very similar.
Do you really think that you can pre-empt it at 19 or 20? At that age you are still essentially a kid who knows very little about life and gives no thought to researching things like this... unless I guess you have seriously abnormal hair loss at that age. It's generally only when you get older that things like this come on your radar!
I don't think you've got much grounds for that assumption though unless you're talking about a maternal grandfather. Baldness is more commonly (though granted not exclusively) associated with the X chromosome so not necessarily anything to do with your father let alone being able to declare that it will follow a given pattern of his.
I don't see why you'd need to have serious hair loss, I mean if you're aware you're starting to thin a bit on top and that you quite likely have hereditary baldness then why wait?
The point is that there are people out there who have spent thousands on surgery and have also been recommended to take this drug to prevent further hair loss, if you're taking that drug and it is effective for you then the whole thing perhaps could have been avoided by simply starting it sooner. I perhaps could have done so later on in my 20s too and ended up maintaining my hair at the point where it was slightly visible as thinning on top but like you I'm not interested in taking some sort of drug-like that on an ongoing basis.
A topical solution or one-off or occasional treatment in future, maybe, but something daily like Regaine, nah, too much faff..
especially when you are (as in my case) visibly and demonstrably following the same pattern of hair loss. That is called empirical evidence.
Sure dowie, like I said lets just agree to disagree and leave it there.Nah, that’s called confirmation bias. You’re welcome to point to some empirical evidence if you like but I think you’re making a lot of assumptions that aren’t really warranted here.
I’ll just note that I did word my post quite carefully if you want to re-read it, there is nothing mythical about what I said, if you look past the headlines of pop-science articles baldness being commonly (note, again, but not exclusively) associated with the X chromosome is not a myth.
