Have you gone for the same board then mike ?
My board is the one in my sig, click on link
Stulid can you check your windows exsperience score for ram as im only 5.5 on my score sure it use to be higher before.
Disable the onboard GPU, then re-run it, Windows only gives a max of that when there is less than 3.5GB, the onboard GPU will take 1GB of your 4GB.
It will then score 7.7ish, you can then re-enable the GPU and ignore the windows experience index for what it is, useless.
Thanks m8 what bios you running im on 1.40 at the moment but i see theres a 1.70 available.
My ram only scores 5.9. so is the onboard GPU on my board still taking 1GB ? even though i have a 5870 plugged in ? :S
the AMD in my sig.![]()
built one for the shop yesturday and its pretty fast
oh well, i dont really need it i spose, or do i
[im]http://i53.tinypic.com/2yoo95h.jpg[/img]
That ok ?
