I have a couple of questions to fellow owners:
1) Where do you get yours serviced?
Just Local Ford Dealer, only got a hendy franchise round this way but not overly expensive.
2) Which companies do you find are best for insurance?
As you know mine is modified a bit which is the state I got it in, but Chris Knott have always been competitive as are adrian flux and greenlight.
3) I Will need new front tyres at some point, any reason I shouldn't replace them with the same ones so they're matching?
Had the Eagle F1's on mine for a while but felt they wore through rather quickly,(7-8k) replaced with Vreds which suit the car perfectly, stiff sidewall and good wear rates (11k ish miles) work well for the car.
4) Why do you all complain about the stock audio quality? I tried it with my iPod via the aux in briefly and it sounds good through the Sony 6CD HU in my opinion - nice full sound, not tinny or harsh like many stock audio systems sound, decent sound stage
Oh dear Howard I thought you were into your music, the standard system is woeful, I only tried it with CD's but felt the sound quality was poor at higher volumes which are required when on the motorway, and it lacked any real kick from the paper speakers.
5) That said.. How easy is it to fit an aftermarket HU? How much room behind is there to shove cables etc? Where do you locate your iPod?
Not loads I had to cut a bit of plastic out with a hot metal knife to get the RCA cables in properly on my pioneer but other than that not a problem, only issue I have is my console looks terrible as due to the fascia adapter it puts weight on it and pulls it out at the bottom, so had to use some glue but couldnt ever be bothered to sort properly.
6) I can't get used to this whole climate control lark; should I just set a temperature, leave it on "Auto" and let it do its thing?
Pretty much, put it on 20-21 and set to auto and it will cool/heat as desired through the required vents.
