Lopéz said:Red Cars Fade
T-cut !
That was AFTER a spot of furious T-Cut action!Simon said:T-cut !
Lopéz said:Well, I did break the black one but that was more a "salvage" operation than breaking a good one for spares (which is what seems to be happening more and more) I never give up on cars until they are thoroughly dead
Lopéz said:Anyone sprayed 2 pack at home? I'm going to give my electric HVLP gun a whirl, not tried it out yet. It's a proper Apollo Spraymate, not a cheapo fence spraying thing![]()
This paint contains isocyanates. If that word looks familiar, think of cyanide. When this paint is being sprayed, the spray can be considered as dangerous as sprayed cyanide gas. In the worst case, death can result from inhalation of 2 Pack paint fumes. In the best case, the immune system is seriously impaired resulting in increased susceptibility to minor diseases and a great magnification of the symptoms.
This paint is not suitable for use by the home painter. Professionals must wear full-body protection with air-fed masks kept at higher than atmospheric pressure to prevent isocyanates from entering the mask. Spraying is done in a filtered spray booth equipped with heating equipment to bake the finish and reduce the drying time.
Only 3!Gaijin said:Exactly how many cars do you actually own Lopez?!![]()
Lopéz said:Only 3!
Probably pop off the gear linkage, then undo the exhaust manifold, rad hoses behind the engine and loosen off the mounts. Oh and take out the driveshafts. Then the engine will be ready to pull I think.Are you going to be putting the same lump back in or are you going to put in a Mi16 or something like that in there? (I haven't gone thru the whole thread yet)Lopéz said:Next step? Err, dunnoProbably pop off the gear linkage, then undo the exhaust manifold, rad hoses behind the engine and loosen off the mounts. Oh and take out the driveshafts. Then the engine will be ready to pull I think.
Nah, I want to keep it 8v.MikeHunt79 said:Are you going to be putting the same lump back in or are you going to put in a Mi16 or something like that in there? (I haven't gone thru the whole thread yet)![]()
Probably for the best - Mi16 conversions can be quite a lot of hassle, and it's a tight squeeze. Someone up the road from me has done it, and he's had no end of troubles.Nah, I want to keep it 8v.
1.9 going in to replace the 1.6. Ideally I'd keep a 1.6 in there but I don't have one lying about.
Keep it up.
