- 13 Jul 2004
- Stanley Hotel, Colorado
Looks like you ripped that driveshaft out with one hand, so I wont argue on your choice of plate font
Is it true that hub nuts usually have a reverse thread? I've tried to undo one with a large breaker bar in the past but it wasn't having any of it... if the thread is reverse then that explains it all!
Makes a change!Nice going Leon, your updates are putting mine to shame![]()
agw_01 said:Fantastic work! Has Kate seen the state of the garage floor yet? I doubt she'll be pleased![]()
" breaker bar, both feet on it and bounce until the nut cracked loose.
Eat more Weetabix/pies.
Leon, Looking good there. Is the 205 local? Wouldn't mind having a gander at some point.
Also how do you rate the Hydrate80?
Couldn't care less about the garage floorFantastic work! Has Kate seen the state of the garage floor yet? I doubt she'll be pleased![]()
I was more concerned with the walking, talking oil slick that appeared out of the garage at about 9pm. He was made to strip within seconds of entering the house
That thing needs a serious dose of Gunk to clean it down, it must weight twice as much as it's meant to given the amount of grime on it.dont worry about that, when i was welding at college it was just classic bird ****[*]I am not the world's greatest welder![]()
Tonights conclusion is that
- Gasless MIGs can weld an inner wing
- It ain't pretty
- Weld spatter takes ages to grind down
- I am not the world's greatest welder
I know that feeling
