My Rally Project
Road rallies (or night events) are run on open public roads late at night. The first cars will normally leave at around 23:00 with most people usually finished by 3am depending on the number of entries and how long the rally is.
Some stages are timed to the minute, interspersed with selective stages which are timed to the second.
There are often regularity or "transport" sections to get you from one bit of the rally to the other as well, these generally consist of a gentle cruise down a bypass or round a town centre.
Over the whole rally you need to maintain an average of 30mph. Which sounds really slow. It's not, unless you have done an event you really won't understand why.
Many of the selective stages are on incredibly tight and narrow lanes with poor surfaces, or down unclassified "white" (the colour they appear on an OS map) lanes, through farmyards etc etc. The more time you drop, the more you are penalised. Conversely, if you arrive early for a check point, you are penalised even more heavily, you have to be BANG on time to clear the stage.
At the end the people with the least seconds dropped wins. There are extra classes for sub 1.4 (or is it 1.3? Can't remember) mixed crew, novice teams etc.
The maps used are Landranger OS maps. The event is likely to either be marked maps (where you pull up at the startline and are given a pre printed OS map with the route on it) or plot n' bash (you pull up with your own maps, and are given a sheet of coordinates to plot on the go) Plot n' bash is VERY difficult unless you have an experienced navigator! In fact, road rallying full stop relies incredibly on the navigator. He has to tell you where to go and how quickly to get there. Without him the driver is no good.
I'll post some more up later but I have to go to work!
Fantastic fun to marshall at these events too and probably the best way you get to know how it all works. There's something very cool and exciting about standing on a country lane at 2am watching a pair of Cibie Oscars rocketing towards you through the night, then signing off their card and jumping out of the way to escape a torrent of gravel as they pull off. Great stuff!!!! :D
My first road rally (a couple of weeks ago) didn't go so well...sideways+ditch+tree :(
Was good until then though :p
just read the whole lot......if I ever have the space I am going to learn more about working on Cars.......maybe I get a scooby to play with....
THIS IS THE MOMENT THEY'VE ALL BEEN WAITING FOR.
THIS IS THE SOUND OF ALTERN-8!!!
Definitely switch to gas and on older metal I seriously find CO2 works better than argon/CO2 mix. Gasless is so messy and it doesn't look like it's penetrated that well on your patch. You really need to get that paint and old crust cleaned off a bit better too. Once it gets into the weld it spits and splatters all over the place as you have found. Tack it in initially just to hold it in place and don't try and weld too far at once. The way I do it is run a series of tack welds round and join them up with short stitches otherwise it almost always blows through.
You should be able to get it pretty neat with hardly any heat going in like this:
And as long as the penetration is all the way in there's no harm in grinding it smooth afterwards if it's on show. I haven't ground these because they will be covered with trim. Otherwise bury it in loads of stone chip and underseal :)
Engine bay ghetto masked
Engine bay ghetto primed
Note ingenious use of mixing cups to mask the strut tops :D
I still haven't got the settings quite right with this gun but my mix was better. My first few strokes were really spattery, after that it cleared up and painted nicely so I think I'll blast few some straight thinners before painting to make sure it's all nice and clean.
Lots of runs :p but the pics hide them. TBH it's only the engine bay so I'm not overly bothered.
Haven't attempted to read the thread, mostly as it covers two years, but also because it's 11 pages long.
I take it doing road rallying is an expensive hobby?
The idea of it is cool, but to be able to do it I'm guessing you have to spend a lot, and not gain much/anything in return (monetary).
InvG
After a little discussion with L1J I have decided to pull my finger out and get this thing finished. And he's going to get this other Golf done in the same timeframe. I'm sure I have lots more work to do though, and I'm spending my own money - not someone elses ;)
So, all things aside, I hope to be ready for MOT by January 4th.
I haven't got a hope :D
Good luck mate :D
This is just what we need!
InvG
Not really that expensive, I've rallied a Sierra that cost nothing - big lights are the only really essential bit of kit IMO apart from mapreading lights (which are the navigators problem) Tankguards and all that are nice but you don't need them unless there are off road bits.
Leon, are you working to a set budget here, or just buying things as and when you need them? i.e as little as possible..?
Yep, just buying as and when.
Safer that way, don't scare myself with how much I've spent!
Most of the stuff I need I already have now - aside from new read drums/cylinders/shoes and a few bits of random pipework and trim I shouldn't need to purchase any new components.
Okay...
Rubbed down the worst of the runs and re-masked the bay
Mix up some lovely nasty paint
And spray!
With flash:
It's er, very red! The shade I've used is Ford Venetian Red which is a fair bit darker than the 205 was originally but it was cheap :D
Lots of runs, all over the bulkhead especially but it will do - and I *am* slowly getting better at painting. Engine bays are not very easy to paint, as I have found out this week!
