- 5 Jan 2010
- London
Hi OCUK!
I was wondering what would be the best air flow through my system.
Here's my current setup:
-PSU is downward facing
-GFX IN-TAKES air
-Green at the back is the Antec 920 cooler, sucking air OUT via the radiator
-Green at the top is currently a Corsair AF120 sucking air OUT of the case, however I will be changing that to a AF140 (120mm vs 140mm, I want 140mm as it fills the gaps in the case)
-2x Red at the front are the Fractal R2 Silent ones sucking air IN
-Motherboard is the Sabertooth Z77 that has two mini fans on it, that ventilate the air in that sort of fashion - to the side and to the bottom.
-Side Panel hole is CLOSED
Here's how it looks like:
My questions are:
-Do I need to suck air OUT or IN from the top - what would you suggest? I feel OUT is better as heat rises and it wouldn't then conflict with the Antec 920
-Should I add ANOTHER fan by the GFX - this is where the side panel is, and where there is no fan there currently (closed)
I was thinking of another AF140 to IN TAKE air into the case, so that the GFX gets a little bit of help.
here's my actual system look at the moment:
Just in case you're confused of the direction of the picture:
The right side is the FRONT
The top side is the TOP
The left side is the BACK
The bottom side is the BOTTOM
Here's the TOP - where the AF120 is in at the moment.
-GFX IN-TAKES air
My questions are:
