T-1 - You should be braking from 6th down to 5th for this turn if your gearing is set right. On the approach DON'T whack on the brakes, dab the brakes whilst dropping to 5th. Off the brakes turn in & try to follow the racing line without scrubbing too much speed off. It doesn't matter too much if you run the wide curbing on the exit, try & take the corner with the least amount of resistance (tyres screeching). Accelerating towards the next turn you should be changing up to 6th around the pit exit on your right.
T-2 - Two ways to take this corner. 1. Brake early just as you enter the red zone dropping to 3rd, turn in & hug the curbing round the whole corner i.e. well inside the predicted racing line. 2. Brake later well into the red zone dropping to 3rd, as your coming off the brakes turn in & power round following the racing line. This is where you may be experiencing the juddering I mentioned in an earlier post. If you are, soften the rear suspension by one notch until it's eliminated.
T-3 - Again two ways to approach this turn. 1. On approach you should be red lining 6th gear. Brake late dropping to 4th & power round just missing the left curbing (if you take too much curb the front pushes out forcing you too wide for T-5). 2. Brake early dropping to 4th, (some may prefer 3rd for a little extra bite) aim to ride A LOT of the curbing on the left. (You can have ALL four wheels on this curb without incurring a penalty)
T-5 - Try not to run too wide of the apex. The racing line is a good indicator of the line you should take. You can be quite aggressive with the car here, power sliding round. Changing down from 4th to 3rd turn in (no brakes) & power round feathering the throttle when necessary until you see the exit then straighten the steering to maximise traction for the run up to the start/finish.
