That's unbelievable driving nikaz. I'm convinced you're the stig.
I don't know how you guys achieve so much speed and still control the car. On the fastest straight I can only achieve about 123mph before having to brake. I could try taking traction and stability off but I know it'll be disaster.
Thanks Nikaz for posting your settings asusual and explaing everything in depth.
does any 1 use a steering wheel ?
Thanks. I assure you I'm not the stig. I don't look good in white.
Practice, practice, practice & oh yeah nearly forgot, more practise.
Try a corner at a time. Don't worry about going off, it's all about finding the limits. I go off all the time finding the limits.
T-1 - Brake late. Seriously you can brake really late. Take a higher line left of the guide line on approach. About two to three car lengths in the red zone, brake hard, turn in hard taking a late apex & floor it.
Remember, if you're going too slowly you're not generating sufficient aero downforce to maximise corner speed. This could be the route of your corner speed issues.
Go practise T-1. if you crash restart. Repeat until you make it. Once you make it round with good speed you'll have a better feel for what the car is capable of. Then move on to T-2 etc. As you improve at each corner, you're constantly getting a better feel for the car so you'll need less & less practise on subsequent corners.
Will practise all that, thanks. However, I really am not able to achieve anywhere near the 150 mph on the straight you're getting, yet I have pretty much all your settings and I've installed all upgrades which were stage 3, aerodynamics and race parts, there was no stage 1 and 2 available. For instance, coming out of T-4, I'm at approx the same speed as you then have my foot to the floor and it's not getting up beyond the late 120's. I tested on another track that has a pretty long straight and after about 126mph, it creeps up 1 mph very slowly but never redlined in fifth gear, and even in 6th it didn't get up much beyond that before I ran out of track. Is my car broken?
I use a xbox360 pad but there are a few users on here with wheels.does any 1 use a steering wheel ?
Interesting. Have you got the latest patch 1.2?
Edit: Are you using auto gears?
Here. Just click AcceptNope. Where do I get that?
merling make sure your pad/steering wheel is calibrated properly
