- 1 Dec 2015
VGA or GPU card .
Did you look at GPU card where cables plug in to see if two LED lights are on ?
VGA or GPU card .
Shall i try diffent gpu power leads from the psu?
LED POWER INDICATORS TO SHOW IF THE PCI-E VOLTAGE FROM PSU IS STABLE
Be alert when PCI-E voltage is unstable with the smart power LED indicators. When experiencing any power abnormality, the indicator will alert gamers by flashing light.
Yes. Should be a second GPU cable with 2 plugs
From gigabyte
If off, then no power
I swapped the power cable from the psu to the gpu to the other set and the 2 leds where they plug in still dont light up? The GPU arous sign lights up and the gpu fans spin though?? Any ideas?
And again , just goes to the AOC splash screen ? Any options to mash Del to go into bios ?
If the monitor is already on but in sleep mode the monitor doesnt do anything when i turn i pc on. I only get AOC splash when I turn it on and off using the power button.
And you've removed the cable and plugged it back in again when it's on ? - same port
Im going to leave you.tonyoyr friday night mate. Will phone overclockers tomorrow and see what they say, I will let you.know how i get on. Thanks for your help again mate!
No worries bud, sorry. Screaming child. You've also got the rep support on here as back up as well . And if it does need RMA, just north of London at least
Morning mate, Inspoke to overclocker technical this morning and they think its the GPU, they are sending the returns label so i can return it to them.
Looks like im going to be pc less for a while!!
Thanks again for your help, I will let you know how i get on.
Enjoy the bank holiday weekend!!
This may sound super daft, but have you checked to make sure the cables are in the right ports, both on the monitor and GPU? Don't mean to offend - done the very same thing before and was convinced I had a dead GPU
Edit: just noticed you've tried a TV too.
Not near Loughborough are you? I could take a look at it if you want to fully make sure it's the GPU?
Fingers crossed mate . Though so with two lights not being on . Might of been with powering on and off. This is why you have a good PSU so rest of components weren't taken out
Ive dropped it to the DPD collection point, wainting game now. Chat soon mate!
