New build need help
Yeah, seems like it to me
Would a manual undervolt cause it? Originally open fishing stimulator and seen white snow in sky, so they recommended UV it. Maybe I went to low? But haven't seen it since just the once. Anyway you could test memory or vram or anything? Before I send card long wait with out a computer lol
Hi Guys, just ordered the Nitro+ SE gonna replace my reference card, should it be a straight forward swap installing into my build? Coil whine is too annoying on my reference. Great hear back thanks
yep. just straight swap
really sorry to hear you had coil whine in your original card. a bit of luck of the draw :(
Yeah recommended what I could do with the reference card return it, trade it in or sell lol also the gpu when connected the fans will be facing down so doesn't give much room at bottom of case should be okay?
Don't know if you could help, im seem to having a issue when restarting its just saying restarting while wee circle going round which will eventually lead to BSOD error 41 power state failure then restarts.. Only thing enable is xmp. Even with it off still causes it. Also mouse bes lagging slow on desktop. Ram timings is different in bios than on Team Vulcan description.
Have you tried running one stick of memory - alternate sticks to rule them out (Use the DIMMA2 slot with both sticks)
I realise you have run memtest in the past but sometimes a physical test is needed.
