New build need help
@Kevin Matthews you're better off not overstretching your finances. just buy the best you can afford now. rather than some omgwtfmonster pc.
i guarantee you 2 years down the line, there'll be something better and greater.
Well that's true i suppose lol what you recommend mate,. Bit of guidence or recommendations be greatly appreciated. Be buying parts next Thursday
RX 5700 good as Nvidia?
it's a rx5700 XT - at stock, it sits in between a 2060 super and a 2070 super
Also the motherboard the bios issue still okay is there any alternative?
the issue is that for a 3600, the newly released x570 boards are overkill - but only the x570 boards will work out of the box for the ryzen 3000 series. also, getting a x570 board means that you'll have to scrimp on some other part of the build.
the value alternative are the b450 boards - but this will need a bios update before it will work with ryzen 3000 series chips.
i suppose the question is: are you comfortable with updating bios on your own?
you could potentially ask ocuk to build this spec for you (ask in the presales section on the forum) and get a quote if you don't feel confident.
but it will be more of a £1400 build due to labour costs
also: windows isn't specced as it makes more financial sense to get a grey windows key on the cheap (~£5)
Dont mine updating the bios as have a mate that help me in the build, also windows key i have on for my laptop already. So no need for one.. That build you posted be fine then? No need to change anything mate?
Also do i need buy a wifi adapter separately?
board already has it inbuilt :)
THE FEATURES OF THE MSI B450 GAMING PRO CARBON AT A GLANCE:
  • 1x PCIe 3.0 x16 (x16) for high-end graphics cards
  • 2x USB 3.1 (1x Type C, 1x Type A) / 4x USB 3.0 / 6x USB 2.0
  • 2x M.2 slot PCIe 3.0 x4 (22110, 2280)/ 6x SATA 6G
  • DDR4-RAM up to 3.466 MHz via OC
  • Integrated WiFi/BT-Module & Gigabit LAN
  • RGB Mystic Lighting with digital header
3600 has a higher single-core performance, also ram doesn't affect performance on the 3600 as much as the 2700.
Multicore-wise, 2700 is slightly faster than the 3600 (8 slower cores is better than 6 faster cores).
But for gaming, 3600 is faster, because single core performance still matters a lot.
TL;DR version: for gaming, get the 3600.
All
All I'll be doing is gaming, so happy with built you suggested for gaming with it be capable of mate?
