New build need help
You can add the conventional drive later when required (the Seagate 1TB) as the SSD should hold you for a while, very simple to do. Or, add now - but tips you over £1400, so psychologically more pants:
i'd get the bitfenix 3 pack fan instead as the stronghold doesn't have the best ventilation
@Kevin Matthews
i'd buy the monitor, case and gpu first - reason being
(1) monitor has free shipping, so you'd want to get the largest items (case and monitor) out of the way first
(2) gpu is on special offer of £475. normal price is £530 when they sell out the discounted stock
£300+475+45 = £820
should be doable from your end?
Think ill go with the Radeon Rx5700 xt more in my budget also going by benchmark its still a good card maybe with bit extra cooling system
You'll probably 'flip-flop' over the next day or so - until your brain settles on a price/component combo that sits right with you. Either way, you'll have a very respectable spec for your money.
Its wild mate lol I've got ps4 Pro which isn't true 4k lol was on YouTube and the rx5700xt seems just as good for FPS
