New build need help
For the power supply what adapter i need for the two pin plug in?
Are you saying your PSU has been sent with a European kettle lead?
e.g.
Alll sorted now, I've got the hdmi and display cable into graphics card that's correct!?
Thanks for everyone's help.. First build ever done :) top service all round
Is there anything i need to do to make sure everything is running the way it should be? Have got windows 10 installed to the SSD.
Motherboard chipset/lan/audio drivers direct from MSI (personally, i would avoid the utility drivers) and latest GFX drivers from AMD. Assuming you got the MSI board and 5700XT.
Presuming you installed MAY update of Windows 10 so 1903 update already installed (allow critical updates only).
Thanks mate. Appreciate everyone's help :)
Hi, was trying to play a steam game, and it said to download latest framework 3.5 and been getting a BSOD twice nkw any suggestions?
https://i.~ibb.co~/Xxy04FH/IMG-20190728-230900.jpg
https://~ibb.co~/RzWkJSL
http://<a href="https://~ibb.co~/RzWkJSL"><img src="https://i.~ibb.co~/72Fd0z7/IMG-20190728-212848.jpg" alt="IMG-20190728-212848" border="0"></a><br /><a target='_blank' href='https://aluminumsulfate.net/aluminum-oxide'>aluminum and oxygen</a><br />
@tamzzy - tns's thread - similar issue - both have same PSU and same GPU 5700XT (although odd symptom - prefer memory or driver issue [perhaps BIOS, some odd issues out there with 450/zen 2])
@Kevin Matthews - how smooth was your install process - did you experience any BSODs before this?
