New build need help
@tamzzy - tns's thread - similar issue - both have same PSU and same GPU 5700XT (although odd symptom - prefer memory or driver issue [perhaps BIOS, some odd issues out there with 450/zen 2])
@Kevin Matthews - how smooth was your install process - did you experience any BSODs before this?
Everything was going great, no problems with installation was running fine. Removed programs and could be driver issue. As a game i downloaded on steam cause the crash originally.
The drivers are still in their infancy (not unusual) - have you tried the latest release linked above?
Not as bad as his but similar when i scroll with mouse wheel theres a whine but never had it until updated bios and latest gpu update there now.
It's coil whine and you probably already had it prior and only just noticed it. Normally it's related to the GPU, but mobo and PSU can be the cause too...it can settle on its own, usually when the chokes "bed in" but it won't fully go away.
reinstall the radeon drivers.
also take a few pics of the internals just to make sure everything is connected properly (which it should be)
Just for part reference - is this the core of your spec? Did you go-off-piste with any components?
Also, if you're still having problems after drivers re-install (remember to restart) - try setting your memory to 2933Mhz and run the test again.
*Additional if the coil whine is particularly irritating you can swap out the card.
My basket at Overclockers UK:
Total: £1,310.83 (includes shipping: £0.00)
@tamzzy - Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, Neo-G, .....
...Oh, and Neo-G.
hah. oops...but no neo-g... (yet)
Indeed. Rainforest marked the mobo as dispatched... hopefully here by Friday/Saturday
Are you playing chicken with your psyche - waiting to see if you hit buy on next day delivery closer to due date for the case?
I've been there - the immediacy of situation can sometimes galvanise your feeling as to what you really want/need.
