New CPU not working with upgrade
10 Jan 2025
Northern ireland
Hi guys, this is my first time posting and upgrading my PC.
I'm upgrading from an AMD Ryzen 5 3600 to an AMD Ryzen 7 5800X aswell as a new Graphics card, new RAM and a new CPU cooler which is a MSI MAG CORELIQUID 240R V2.
The new cooler isnt installed yet because of missing brackets to install it so I've been using the old cooler which is an AMD stealth socket.
The RAM and Graphics card work fine with the old CPU and cooler. But when I put in the new CPU with the old cooler all the lights turn on, all fans spin, but the red light for cpu stays on and there is no display on the monitor.
Anyone know if this is due to a problem with the new CPU or the old cooler not being the right spec. I can list all my parts if needs be.
Motherboard - MSI B450 TOMAHAWK MAX ATX AM4 Motherboard
CPU - old is 6 core, new is 8 core
Graphics card - Radeon RX 7600 XT 16GB
RAM - Corsair Vengeance LPX 32 GB (2x 16gb)
CPU cooler - listed above
So today I was able to find time to do this, and it's not working. The red CPU light is still on and no display is showing. Should I take it to a tech shop and have them take a look at it or what should I do.
If you're 100% sure the bios upgrade was done correctly then it's a DOA chip
^^^I have am4, not sure I have EXPO with ddr4.
The old cooler if installed properly should see you into windows I would have thought.
Pins ok?
Does the bios need that incremental flash business where you need to wipe Bristol ridge with a flash before getting 5000 support with another flash.
Pins ok?
I am not an AMD expert so I don't know which standard works with what, but the point is that you must run the RAM at default speed. All forms of XMP and XPO are overclocking and while they may work with one CPU they may not with another.
What bios did you flash to?
Latest is a beta version (but should be ok).
If you flashed to this, try the one before (7C02v3J). You may have to use "bios flashback" to downgrade.
I watched a video about the same motherboard as mine, so I used the non-beta bios, used the msi mflash to do it, waited the full time for everything to download and stuff like that so I think I done it correctly
Did you clear the BIOS? Make sure that the RAM is set to default speed and not EXPO. Could be that the RAM worked with the old CPU but not the new one.
I'm not one for overclocking as I wouldn't understand what I'm doing, so everything is set to default. The new RAM is the same as my friends who has the same cpu and his works fine so I'm not sure.
Pins ok?
I've been installing the old cooler the same way with old and new cpu, works with old but not with new. All the cpu pins are straight and none are missing.
I'm not too sure about the incremental flash as I know next to nothing about stuff like this
