10 pages of intel nuc owners no one fancy answering my question above ?
Not unless it really is that bad at multi-tasking !
Ahh! I was wondering about this. I also have an AC-7260 and running Openelec I have occasional minor hiccups. Might swap it for a lesser wifi card from an old laptop for the time being.Only issue that i have with it is the flaky wireless which is a known issue with the Intel 7260 Wireless , i hope that they will sort it out with driver updates soon.
They are absolutely incredible. My Haswell i5 NUC running Openelec (a cut-down Linux distribution with XBMC built-in) consumes 11 Watts, and with the screen suspended (basically the TV goes black) it consumes 6 Watts!
I have recently brought the Intel DN2820FYKH NUC which i have put 4GB Ram and 500GB Hybrid Drive in it , Installed Windows 8.1 Pro and XMBC.
Works well with no stuttering at all with the videos in my library.
Most power meters are pretty generic the ones off flebay for a tenner or 15 quid do the same job, try and get one with a battery to remember the settings and one that has a large and clear display though usually around 15 quid.
I have one but not sure if its accurate as it says my Htpc uses between 7-15 watts as it Fluctuates but normally sits around 7 watts most of the time.
My setup is
AMD A6-3650 Quad-Core Processor - 2.6GHz, 4MB L2 Cache, Socket FM1
AsRock A75M-ITX Motherboard
Crucial 60GB ssd
Western Digital 2TB SATA Internal Hard Drive
Test it with a lamp that has a bulb with the wattage stamp still visible, i.e. a 40W bulb should read pretty much exactly 40W on your meter.Tried reset still same but i am using a pico psu so that helps some, i did have a meter from Asda that showed a lot more watts but had to take it back as the clear plastic on the display fell off.
I think i might call at my local electronics shop to see if they can test it for accurancy.
Also only checking what wattage pc uses as its plugged into my tv.
