- 20 Oct 2019
Don't get a gray key, your ripping Microsoft off what did they ever do to you. It's technically stealing
Post in the customer services section of the forum and ask if they'll honour the Christmas deals prices. (They should do imo)Dammit! I was too slow! The CPU is now £159 and the memory is not in stock until the 9/1 and costs £56... you snooze, you lose!!
Also if they were worried about it they would stop their own Media Creation Tool allowing you to upgrade from 7 to 10 for free still even though it ended ages ago.**** that, they make more than enough money!!!!
In what way? Its worked fine on my current PC for a couple of years? How much is a decent new one?
Had not thought of that - but they are both 7 years old with no packaging ... where would I sell them - I don't do Ebay anymore? Although I suppose I could find my old account.
My basket at Overclockers UK:
- 1 x AMD Ryzen 5 Six Core 2600 3.90GHz (Socket AM4) Processor - Retail= £128.99
- 1 x Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30= £49.99
- 1 x Asrock B450M Pro4 (Socket AM4) DDR4 MATX Motherboard= £70.99
- 1 x PowerColor Radeon RX 570 Red Dragon 4096MB GDDR5 PCI-Express Graphics Card= £119.99
- 1 x SPEEDLINK Event Slim-line USB 2.0 Powered Stereo Speakers, 5W RMS, Black= £9.95
Total: £391.01 (includes shipping: £11.10)
@IMissMyDCast your monitor is plugged to the GPU outputs?
Which RAM slots were you using? According to the manual it should be slots A2/B2 for 2 sticks of RAM.
For the cable connecting monitor to PC, is it connected to the GPU or motherboard?
is it working now then?I did try the motherboard until I realised this processor doesn't have GPU capability!
So is everything working as it should then?No, sorry, that wasn't clear. I'd already realised I couldn't use the Mobo for the display. I am currently using my old graphics card
I think the CPU is a 2600, so BIOS should be able to POST without issue.Does the motherboard box say Ryzen 3*** compatible, or have a bios version anywhere on it?
Nope, not working at all. Didn't even beep when I turn it on.So is everything working as it should then?
Or still having issues?
is everything seated correctly? is the cable(s) to power the graphics card installed?
also i wouldnt always go by what the manufacturers list as compatible ram, i have the b450 aorus m motherboard with ballistix sport lt ram which were never listed on the support page and i never once had issues
