£639.98 for the 27" 950D!
No thanks.
Wasn't it £40 less a few weeks ago?
Im soon give up waiting for the 750 series.
A delay this long without a single press release from Samsung about it? Seriously?
The hack doesn't work for me as Windows can't find the correct drivers.
Can you tell me what drivers your "Simulated USB HID Receiver device" loads?
Cheers
hello all, wander.. if you can help...
didnt see the point in creating a new thread so thought id plonk it on here...
i currently have a 6950 and looking at getting either the 950 or 750...
now im not the best with all the tech stuff but i understand i should get the 950 so i can play at 1920x1080 at 60hz an eye, due to the dual link dvi as the 750 only has hdmi which wont be able to handle the amount of data transfer.. would this be correct?
TestGeericHid.wsf starting
Setting diagnostics for external hub
Setting endpoint diagnostics for configuration 1
Setting endpoint diagnostics interface 0 alternate 0
Endpoint.Setobjectflags for interrupt IN endpoint 1
Enumerating simulated devices to look for a simulated EHCI controller
Configuring genericHID device as a USB 1.1 full speed device
Setting generic hid device logging to true
Setting diagnostics for genericHID device
Configuring genericHID device is necessary to load descriptors
Press enter to unplug genericHID device from external hub
hmmm... what would your advice be ? i obviously for the price i want the best performance possible of the monitor...
http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-MS
thats my Gfx... as i will be running 3d if i can
im sure ill be ok however im deciding which would be better hdmi or dual dvi...
you see i hvnt got a clue about the whole display port thing , i do know that dual dvi is better... question is... is it worth the extra £100..
how is the 3d with the 5850 and also what software you use?
watched Oc's vid on the 950 and it seems the monitor does the 3d itself.. how does that work in conjunction with the amd side do you still need say tri def?
How is the 3d with the 5850 and also what software you use?
