** NEW SAMSUNG 750D & 950D True 120Hz LED Monitors - PRE-ORDER! **
I believe the only difference between them is the 950D has a Dual link DVI port a HDMI and a DisplayPort where as the 750D just has the HDMI and DisplayPort.
So you must have a Displayport on your graphics card if you want to take advantage of the 120Hz on the 750D as I think the HDMI is locked at 60Hz.
Thanks. orded one. looking forward to monday now, never thought i'd say that with it been the weekend. :D
I absolutely cannot get TriDef to enable 3D when I run it with frame sequential selected. If I choose side by side it does what I'd expect, I turn the monitor to the same and I get a 3D image. With frame sequential selected, I get a "3D is currently disabled...." message.
Now that would all make sense if I had an Nvidia card but I'm using a Radeon HD 5850. Anyone else had such issues?
I updated the software that came on the CD and am using Catalyst 11.8 so the issue doesn't lie there.
The SA750D does have 2D-3D conversion. It is part of the HR3D engine which is identical on all members of the SA series. I think it could have been CNET who erroneously stated otherwise - but this was back in January when information was sketchy. And it works much better on some things than others and has a generally very weak depth effect - but is generally very smooth.
That is excellent news, thank you :)
Can't wait for the UK release of the S23A750D
I got the last one at the price of £549.99 and I am very excited. Can't wait for it to come through the door! My old NEC broke and I have been stuck with a tiny 17" for a couple of weeks already.
Hmm guess I'll wait for either the 950 to drop to £500 or wait for reviews of the S27A750D.
I know so many people that want the 950 but its priced way too high, especially when you see how cheap it is in Australia.
You'll be waiting a long time for it to drop to £500 I feel. The £549.98 was an offer for five units only just days after it had been at £639.98 due to a low number of available units. After all that it has now returned to £599.99. Given that the 750 is priced at £529.99 it doesn't really give a lot of scope for a price drop even if both were to be reduced.
Just to confirm, what exactly is the difference between the 750 and 950?
The base?
Aesthetics, price and their connections.
750:
950:
There's always HDMI Switchers. And their not expensive at all. They are Computer monitors first and foremost.
I use a 5-way HDMI switcher that I bought from where you get Kindles (!) from and the siwtch only cost 20 pounds, with automatic signal switching and a remote control for the times auto get its wrong.
just recieved the 950 today, just finished installed the drivers / Tri Def. How can i change it to 120hz? using a 5870 atm connected via HDMI when i go into ATI settings i does not give me the option or am i just dumb. :D
You won't be able to run 120hz at full resolution using HDMI as it doesn't have the bandwidth to support that.
