- 14 Aug 2009
If you get some "good" optimization going on, like FC6 and its high texture pack, 8GB are not enough even for 1080p....Not a lot of point in 16GB if the card is no where near powerful enough to handle 4K, or raytracing.
It would just add cost.
Also, the spec is probably wrong because that guy just makes stuff up, and frequently changes his mind then says that 'the information has been updated'.
I guess it gives AMD an opportunity to be a bit more generous with their spec at the mid end, if Nvidia does go with 8GB for this card.
In a way is understandable that older cards have lower vRAM, but the minimum should be starting at 12GB nowdays...
