The fact that GTX960 peforms virtually on par with 280X with less than half the TDP, one third of the bus size & two thirds of the memory is testament to how far ahead Nvidia are and probably the reason why AMD are making so little profit.
For me when performance is roughly at the same level, TDP/heat/noise are far more important than some paper specs.
I think everyone might be missing something here. With such a low tdp these may be great overclocking cards. If some manufacturers stick 2 6 pins on these you should be able to get some great clock speeds and fps.
I'm just thinking of the 460.I have got in my computer and how much overclocking I managed on it.
I hope this is the case with the 960, otherwise it will be a real flop.
Should have done that in the first place as soon as those spec leaked. Now the 970 is much more expensive during to weaker pounds, as well as close to the release of the 960 also lead to slight inflation to pricing as well.So those of us that were waiting, might as well just get our 970's like we planned![]()
Those guys that insisted Maxwell is so awesome that 128bit memory bus won't not drag down the performance really ruin it for the others.
If it beats it's AMD rival while using half the power and putting out less heat, and AMD say it's unappealing, does that make their card repulsive?![]()
It certainly will for anyone using any level of AA or higher res texture- it's been proven again and again that low memory bandwidth will lead to greater frame rate loss when AA is applied; while yes it is true 512-bit bus most probably won't benefit comparing to say 384/256-bit at 1920 res, as having higher than memory bandwidth than required for the data throughput will not see increase in performance, but have less that what's required will result in poorer performance immediately.Has the 128bit bus dragged down the performance then? I have seen nothing that shows it has and do you think a 512bit bus with 8GB of memory will suddenly put it to the top of those charts? You need to read up on what is what when it comes to GPUs really before making such silly statements.
Better off picking up a 7950/70 from members market for under £100. Get a lot more performance and save quite bit a money in the process.
You arguement is like saying "4GB of vram offer no benefit over 3GB of vram for 1920 res, so how can you say 1GB of vram is not enough"
And please don't use the generic arguement of "this card is not meant for maxing gamings out", as people that use cards such as GTX770 or 7970/280x will use AA as well, so there's not reason why this card should be running games without it. Provided that if the 960 had both the model of 128-bit and 256-bit version, at 0xAA the chance are the frame rate would be the same, but as soon as 4xAA or 8xAA is applied (even in the not so demanding games), the 128-bit model will lag far behind and end up being much lower in frame rate than the 256-bit model.
why are they testing it with AA settings enabled..?
GTX960 / 2GB RAM cards are designed to play at 1080p with no AA enabled, where it should achieve 60 fps in vast majority of PC games available except for crazy demanding ones.
edit: oh yea, cos the AMD cards can run those games with AA enabled. well GG to AMD then, they still have some superiority in the sub £250 market then :3
Who's this card aimed at? People who only buy Nvidia (60%+ of the market) and have £150 on a gpu and who probably havent bought a new gpu in years so for them it will be an upgrade, or even they dont have a gpu
Whatever nvidia release will sell well, the reasons why that is have been hashed over so many times and whatever I say people will try to argue arent true, so i wont bother, but obviously there is a big chunk of consumers who only buy Nvidia so it is irrelevant what anyone thinks as to why.
