Are there any reviews floating about which compare the various custom cooled 970s?
I agree with this. Since the GPC are arrange in clusters of 4 SMM and since the gtx 980 is made of 4 GPC, you have 16 SMM or 128x16 = 2048 shaders. SO something scaled up should contain additional blocks up of 1 GPC or 4 SMM more. Unless they change the configuration again like they did with the gtx 750 ti(which had 5 SMM in one GPC).
So scaling up and considering the current die size(398mm2), they should be able to fit 6 GPC or 24 SMM or 3072 shaders, 96 ROPS, 384 bit bus if they tighten the transistor density a bit. They will need to do this because these large chips they focus on double precision performance, which adds a tad more to the size. So I am guessing a slightly bigger maybe 620mm2 chip, with 30-40% more performance than this chip. But of course 1200 dollar price tag or something ridiculous. It's going to be hard to get good yields from a chip like this and we are likely to see something with just 20-25% percent more performance from the cut down version meant to be sold to most people.
Would a single 970 be significantly better than my single 7970?
Who cares what it looks like?
The Swiftech blocks on the Hydro coppers don't even actively cool the VRMs.
Head over to Anandtech and bench a 7970 against a 780ti (or even the 970 if they have it added already), and that should give you the information you need to answer this.![]()
Any word on release/clocks/price?
The 780 hydro coppers were a 780 FTW with a block attached if that's any help.
As I said earlier I am done with this the thread is about the 970/80 reviews.
You should not assume as much as you do
My first job was for an accountancy firm doing accounts.
Most of your facts in your last post are still wrong and I am not going to take time to correct them as this is not the place.
Techpowerup have a 970 review for the EVGA SC ACX which compares a small number of OC results. Also compares this card vs ref in games, noise, power etc.
Probably have reviews for each major AIB, though I haven't read all of them
Yes,but you are both forgetting that the GM200 will have better DP performance which adds to the transistor budget massively.
The GK110 had twice the number of transistors as the GK104 and was nearly 90% larger in surface area. Yet it was only around 50% faster at 2560X1600 according to TPU.
Maxwell is already more massively more efficient at compute performance over kepler, Kepler had bad SP performance and really awful Dp performance, it will take much less work to convert small maxwell in to a DP monster than it did with GK104 to GK110
Tempted by the GTX970. I have a GTX780 now so I know the 970 would only be a bit faster, and so maybe a bit of a side-grade. However I do a lot of streaming so the H.265 encoder in the 970 should give a nice improvement to stream quality. Also using way less power. Anyone know if it is a full hardware H.265 encoder? I read somewhere it might not, and would be a mix of hardware/software encoding.
I'm assuming Titan2 will be 20/16nm, they would be mental to try to do it on 28
GM204 has 1/32 DP performanceover keplers 1/24, hence the small improvement, but it wouldnt take a huge amount to improve that, so yes improving dp performance will eat in to mm2 allowance, but not by as much as it did with gk104>gk110
Ifnyou put a Titan in to full DP mode it has 1/3 dp performance, but maxwells SP performance is so good you could trim that back to 1/6 and still have a beast of a card
