NVIDIA GEFORCE GTX TREATS FOR GAMERS ONLY (MINERS NOT FOR YOU!!) !!
code on the gigabyte 1080 G1 doesnt seem to work anymore, has it expired? i was hoping to order one when im back from Korea in Aug :(.
looking at swapping my 670's to a single better card solution. Will want a waterblock too sadly everythings just so pricey at the moment though
Try ebay for the reference cooler for it if you sell it later on, I'd buy one right away though so it's there and not 4 times more expensive when you need one down the road :P
Is that all I would need to do is remove the older watercooling block and add the new cooler?
Try ebay for the reference cooler for it if you sell it later on, I'd buy one right away though so it's there and not 4 times more expensive when you need one down the road :p
Can anyone give me any links to a reference blower for this card?
I'm assuming this is going to be much cheaper than any of the new vega cards
1. Yes, just remove the block and add the cooler.
2. Depends on whether this is a reference PCB or the MSI custom one from their Gaming X series. Either way, getting the right heatsink/fan (ask MSI if in doubt) would be as simple as applying thermal paste and screwing in, theoretically. Before you start looking at buying coolers, I would check with MSI directly TBH.
3. Doubtful. RX Vega 56 will likely launch at £399 (prices seem to be 1:1 for USD these days) and and RX Vega 64 will likely launch at £499. I imagine waterblocks for Vega will come about reasonably quickly, given how high their TDP is looking, and how well they respond to lower temps and undervolting (see: Vega FE reviews).
