You give any electrical part 2.5x it's rated current and it will thermally fail, not if, just when.Bit of an assumption there, but it’s a possibility, although it didn’t happen…
Then why imply it?That's all that happens. Throughout this whole saga, no one's GPU has "blown up" as you put it
I don't recall any 40 and 50 series cards on fire or exploding
No need to tell me how electrics workYou give any electrical part 2.5x its rated current and it will thermally fail, not if, just when.
To make sure I understand, his Lian Li cable melted, but he is also buying a new PSU to replace his Corsair one? So a Lian Li cable + Corsair PSU. Not saying that is the reason for the melting, but it's not good to mix and match.
Another one....
At this point given how many are melting considering the tiny number out, I experct to seee WAY more after next month once these magical stock supplies ramp up..
570W from pins this thin lmao. Good luck to all who bought or will buy a 5090.
That was overly dramatic language on my part. My mistake.That's all that happens. Throughout this whole saga, no one's GPU has "blown up" as you put it
Going off the reddit megathread, which is about as much as we have right now, there are two confirmed FE 5090s. On top of that there are two more FE 5090s which genuinely seem to be user error (very poor cabling practices, risky under any circumstances). There is one confirmed Asus 5080 Astral, which is weird and currently the only non-FE (and non-5090).Have all the 5090 connector burns been with the FE so far? Does anyone know any AIB cards burnt?
Back during 30 series crypto mining we had the 3090 at £2.5k the 3080 at £1600, 3070 at £1200 and 3060ti at £1000Yeh i see your point. The 4xxx wasnt great either historically, but i still think the 5xxx series is even worse.
Prices have gone a bit silly after the 3xxx series (and people even thought those RRPs were high at the time!) generally which is very disappointing.
Thanks for the summary. I forgot about the reddit megathread. I agree regarding FE vs AIB, but I do think many more FEs are in customer's hands at this point.Going off the reddit megathread, which is about as much as we have right now, there are two confirmed FE 5090s. On top of that there are two more FE 5090s which genuinely seem to be user error (very poor cabling practices, risky under any circumstances). There is one confirmed Asus 5080 Astral, which is weird and currently the only non-FE (and non-5090).
Don't read much into this, though. Sample sizes are incredibly small and there is just not enough evidence right now to conclude "FEs melty, AIBs safe". FEs have been a very significant chunk of the 5090 supply so far - there certainly seem to be more of them around than any one AIB model and possibly almost as many as the AIBs combined, due to that "communication issue" between Nvidia and AIBs.. They're all putting a similar level of power through that cable and we'll see whether other models are affected once more of them flow through into circulation.
It's all user error, why would they even think about a recall?TBH I'm kind of surprised there's not been much (any?) talk about a product recall, either instigated by Nvidia themselves or forced on the by whatever government body deals with that sort of thing.
Whilst you are in this thread, Jensen, have you got a spare 5090 for me?It's all user error, why would they even think about a recall?![]()
That's exactly what Derbauer said too - he's been running these tests for just minutes. If it was an hour+ of intensive gaming, you'd see melting. And with higher power use we'll see way more of these cases with 5090 than we've ever seen with 4090.I guess the reviewers are only running relatively short benchmarks in open air rigs.
3080 was the last card Nvidia made that didn't burn your house or wallet down.
Agreed, and it makes sensxe anyway, since the vast majority of sold and delivered 5080s and 5090s are FE. So far it's probably just propability since there are more FE card being used than AIBs.The reported cases yes. But there's no electrical reason it can't happen on any card. Construction of the cable seems to be the biggest variable/culprit outside of the fundamentally flawed design of course.
I know that was sarcasm, and it's not like we haven’t already seen plenty of finger pointing at various culprits, but i do find it concerning how a company can sell a device with such a badly designed power delivery circuitry it seems to be more a case of when, not if, it's going to cause a fire.It's all user error, why would they even think about a recall?![]()
Yeah this is the route of the problem. It's quite clear now that anyone with a financial stake in 12VHPWR cannot be trusted and some regulatory body should be stepping in. If you think about it, anyone with enough electrical engineering knowledge to produce some product that uses the 12VHPWR standard, has enough engineering knowledge to spot straight away that the spec is bad and potentially dangerous. This includes AIB vendors, cable manufacturers, PSU manufacturers. They all probably knew and yet they all marched ahead releasing their products and taking money off people. He's deleted his Reddit now but I'm pretty sure the Corsair head of R&D has said several times how he 'doesn't like' the spec. Obviously not going as far as to say he thinks it's dangerous because then questions would be asked why they're selling a product using a dangerous standard.I know that was sarcasm, and it's not like we haven’t already seen plenty of finger pointing at various culprits, but i do find it concerning how a company can sell a device with such a badly designed power delivery circuitry it seems to be more a case of when, not if, it's going to cause a fire.
