ASUS GeForce RTX 5060 Ti TUF OC 16 GB
https://www.techpowerup.com/review/asus-geforce-rtx-5060-ti-tuf-16-gb/
Any 5090 owners here with AC shadows? Just wondering whether 59fps average, native 4K, everything max is correct? Also peaked at 63C during the benchmark, all ok?
I can enable DLSS, but it kills vsync.
So I turned on DLSS and then vsync via the Nvidia control panel since it’s disabled in game. Is this how I should be doing it?
Yeah. V-sync and G-sync on in the Control Panel/Nvidia App. V-sync off in games
The tone of the 5060ti 16GB reviews I've seen has been pretty negative, but a lot of that seems to be down to a combination of anger at a) Nvidia's dishonest marketing (again) and b) generalised fear in the US about where prices might go with tariffs.I wouldn't call the 5060ti awful. Yes, you can get much better performance for a little bit more, but for people that have itx builds, show me a card that's below 210mm that has similar performance? There is none (well, there's 1 4070 by gigabyte that's out of stock everywhere that's 200mm).
Bro you got all year sauna for free. I use a portable aircon in my room during summer, but I plan to invest into a proper split aircon this year tho.Downloaded The Last of Us Part 2 last night. First game I’ve played, so far, that draws the full 600W down the melty cable with my big overclock. I have the Xtreme Waterforce.
The frigging heat in my apartment after 30 mins was insane. After 8 beers last night I thought it would be funny (and it was to be fair) to stick my face on the front of the case where the radiator is attached. I now look like Harvey Dent from Batman.
But in all seriousness jeeeeeeeeeeeeeeeez the heat. Glad that’s going through a radiator and not into my CPU AIO…. Voltage is like 1.03V ish @ 3200Mhz ish. Think that’ll be one where I have a different profile active
Weirdly I’m still getting tearing with frame gen on. Seems okay if I use quality upscale instead since vsync seems enabled again in game.
Keep in mind, it depends what type of socket is soldered to your card (standard or reversed), and what direction you need.Could anyone recomend a good quality 12vhpwr cable for a 5090, ideally 90 deg or designed to be flexible. Was rather shocked at the dreadfull little one that came with my Gigabyte card that just turned up
My bad, been doing some digging and I need one with 4x8pin connectors on it as my PSU doesn't have a 12vhpwr portKeep in mind, it depends what type of socket is soldered to your card (standard or reversed), and what direction you need.
I am currently using this one:
Seasonic 90 degree 12V-2x6 adapter cable
But I will use Style B from Corsair once the Alphacool waterblock arrives because I need opposite direction:
CORSAIR PSU 90° 12V-2x6 Style B Cable
Both seem good quality, the Seasonic one is pretty expensive.
