On my x1800xt PE i am running the game at 1280x1024 with HDR as the difference between that and bloom is fairly high actually
In lush areas like this one the Fps ran from 32-42 fps usually around the 36 mark! This was when running in HDR mode
In more common areas with less foiliage you can see the frame rate running at 45 to 60 fps dependent on lens flare, foiliage etc again this picture was taken in HDR mode *Note the effect of the sun around the trees as this is where the noticable difference between HDR and bloom become apparent*
In the final picture this is in bloom mode with 6xAA and basically people who say the effect is the same it isnt, it is even more apparent at dusk, however the game runs around the same speed most of the time however it tends to be faster at other points. *Note the effect of the sun around the trees as this is where the noticable difference between HDR and bloom become apparent*
Indoor areas like dungeons run at a very VERY smooth frame rate, well over the 100's at times! these sections are when the game runs at its best and it was practically always over 75 in these sections.
Everything was obviously ran at the highest settings and the gain/loss between HDR and Bloom+AA was really negligable, all in all the HDR does look much MUCH nicer in sections so I have decided to run in that mode!
Any other guys wanting to comment on their results feel free!
