** OcUK EXCLUSIVE: SUPERFLOWER POWER SUPPLIES NOW IN STOCK!! **
Hi there
Right, the Amazon range has arrived, same Superflower quality and reliability, but at a very affordable price point. We are not supposed to sell these as they are designed more for our SI side of the business, but we like to offer our customers the best deals:-
SuperFlower Amazon 550W "80 Plus Bronze" Power Supply @ £49.99 inc VAT
The SuperFlower Amazon power supply still brings you the amazing quality you've come to expect from Superflower and the Amazon range keeps the reliability whilst hitting a lower price point. It still has 80+ Bronze certification so for the money is one of the best value and most efficient power supplies on the market in this price range.
Features:-
- Support all Intel and AMD Dual Core and Quad core and its compatible Motherboards, ATX/BTX compliant.
- EPS 12V Ver2.92 with four sets of individual 12V output.
- PCI-E power plugs are setup in a 6+2 configuration for the latest graphic cards.
- Patent 14cm LED Low Noise Fan, Great air flow for heat dissipation.
- Multiple Protection Design:OVP,OPP,SCP
- Switches on/off test for more than 2000 times.
- Passed 80 PLUSR Bronze Certification, which has the Power Efficiency?82?
- Full Range APFC, support 100V~250V.
- Multiple safety certificates acquired.
Specification:-
- Real Power Output: 550W
- Transform Efficiency: on 20% 50% 100% loading, with 82.03% 85.14% 82.67%
- Intel Power Design Guide: EPS Ver. 2.92
- Outlook: Honeycomb ventilation panel, high efficiency air flow
- Fan Size: 14cm Silent Fan with temperature control
- Dimension: 163mm(L) x 150mm(W) x 86mm(H)
- Protection: OPP?OVP?SCP
- Safety Certificates: BSMI R33529 / CE / FCC / CUL / TUV / CB
- Cable Wires: 20+4pin
- Fixed: one Cable
- 4+4Pin CPU one Cable
- 3x Molex with 1x FDD
- 3x Molex
- 3x SATA
- SLI 6Pin&6+2 Pin Connector two Cables
- 3yr Warranty
Only £49.99 inc VAT.
ORDER NOW
SuperFlower Amazon 450W "80 Plus Bronze" Power Supply - Blue LED @ £39.95 inc VAT
Features:-
Specification:-
- Real Power Output: 450W
- Transform Efficiency: on 20% 50% 100% loading, with 83.22% 86.61% 85.62%
- Honeycomb ventilation panel, high efficiency air flow design
- Cable Wires: 20+4pin Fixed one Cable
- 3x Molex with 1x FDD one Cable
- 3x Molex one Cable
- 3x SATA with 1x Molex two Cables
- SLI (6Pin&6+2 Pin) Connector one Cable
- 3yr Warranty
Only £39.95 inc VAT.
ORDER NOW
SuperFlower Amazon 300W "80 Plus Bronze" Power Supply - Blue LED @ £29.99 inc VAT
Features:-
Specification:-
- Real Power Output: 300W
- 3yr Warranty
Only £29.99 inc VAT.
ORDER NOW
Still 80+ rated and Bronze certification. :)
All reviews state zero buzzing and no electrical noise, they are quieter than the Seasonic versions for sure.
We've sold about 30 units so far, not a single one returned, so customers very happy with them, as always buy one, if your not impressed, send it back under 14 day DSR terms we offer. :)
That's very reassuring Gibbo, thank you for replying :)
As good as they might be, what should crap brand name :(
what does difference does the brand name make?
as long as in the factory/assembly line they are doing business
Would be interested in a Leadex 650w :D
i have been on SuperFlowers website, they do a lot of power supplies, just in the Leadex range, i am sure Gibbo etc were seeing how the high end ones sell first, big them up, let the name be known then start selling the lower powered ones...... thats what i am hoping for anyway
At one time all PSU's used to just have 3 year warranty. 5 year warranty on these same as Coolermaster, Silverstone, Enermax, but Seasonic and Corsair offer 7 years recently.
Maybe SuperFlower should up the ante and offer 10 years just like the EVGA SuperNOVA ones without the 50 pence worth of LED's.
If you check the Jonnyguru, Techpowerup etc reviews they are exactly the same internals, but EVGA offer twice the length of warranty for 25% less price.
Both SuperFlower, and EVGA plus retailers making a profit, it makes you wonder whose getting the extra £50+ on these SuperFlower units, I bet it's not them plus no middleman.
It just sounds like a horrifically cheap and nasty brand. I know they're not but the first thing that comes to my mind is that, I can't change that :p
shatpank81 said:
I have an evga one, its noisy as hell!
That as the loudest fan in my case
Nelly said:
Which one you got?
shatpank81 said:
650w supernova gold rated
The 650W and 750W are made by FSP, the NEX1500 by Extasis - loud fans, poor reviews.
The 1000W Gold/Platinums are made by SuperFlower minus the 50 pence worth of White LED's - quiet fans and excellent reviews.
So what your saying is the evga is/should be noisy?
Or the superflower lower watt psu's will be noisy also?
1500W EVGA SuperNOVA NEX1500 Classified, 750W/650W EVGA SuperNova's have loud fans, average reviews - do not buy.
No reviews of the SuperFlower lower wattage PSU's, I doubt they will be loud at all, need them testing properly by Techpowerup, Jonnyguru etc.
I'm saying the SuperFlower PSU's are brilliant, but they are overpriced, mainly due to retailer wanting to make good profit margin, and supply/demand.
EVGA give 10 year warranty and usually priced 25% cheaper, why would I buy a SuperFlower?
SuperFlower Leadex Platinum 1000W or EVGA Supernova P2 1000W, you are getting the same unit, except different coloured cables on the EVGA, and no 50 pence extra of LED cable sockets, they both run quiet.
See this graph below for the above PSU's running ECO mode.
Read through reviews, that's what I do, the proof is in the pudding so to speak.
Click Here >> Techpowerup PSU Review Database
Click Here >> Jonnyguru PSU Reviews
