Brilliant PSU ive had my Leadex 1000w gold just over a month, bought on 7th jan, however this morning I fired up my pc to be met with a nasty metallic squealing noise coming from the psu fan, its attempting to spin and failing repeatedly, with the odd squeal noise.
No choice but to RMA it, hasnt dented my opinion of this product though, still the best psu ive owned
Sorry to hear you have troubles with this PSU. Mostly any noise should come from the fan and from having a 1200W Leadex myself its practically silent, did you observe if this happened under certain loads?
Why is there nothing fully modular below the 1000 watt version and above 550 watt? Do Superflower just not make them?
I would have thought there was a market for a quality Superflower modular 750/850 watt PSU.
Meh, my 1000w gold now has the fan squealRMA time I guess. Seems to be happening more and more.
Happens as soon as the pc is booted up, and then sporadically every 15 seconds or so. I had a look and the fan is not spinning, it is attempting to but failing
The amount of these that I've seen as faulty is crazy, struck them off my list now, will get something else!
I could hear the noise and visibly see the fan struggling when I pulled the side panel off. Think I will just RMA it in all honesty
Just had a look its in ECO mode, if i flip it into AUTO the Fan makes a nasty grinding noise, i think the PSU itself is fine, it just sounds like the fan is not working as it should.
Will whip it out and box it up to be sent back.
