Rog Formula, Xspc waterblock, and teamgroup 16gb kit in gold.. Yeah I know, this is going to be a pita to sort out colour a colour scheme. Just waiting on my case and the Photon res/pump combo. I'm as happy as a Fatherless male child on Father's day
Turn around from ordering to shipping was fast though, I was shocked to say the least
It all depends on how much watercooling you use and how much voltage you are willing to try.What max clocks are peeps getting with these chips?
I think they'll all do 4.9/5.0 with a good watercooling set up if you are willing to push to 1.4V or beyond.
We are just finishing off a couple of systems using the same chips, i think we are launching them at 4.8GHz with less than 1.35V
Guys I'm a little confused, got this installed tonight and it works fine apart from the fact that it never steps down from 4.6Ghz even at idle. The speedstep settings appeared to be setup correctly.
Any ideas?
Cheers
Fred
Hi Fred,
I have the same problem - I hope someone has an answer for us as it seems silly to always run at 4.7Ghz and 1.31V in my case. You using an X bios or standard bios? Maybe the X bioses don't allow it to ramp down at idle. Hopefully Pgi or someone will be along to advise us.
Great board though I must admit.
Cheers
Mark
I figured it out, I usually set my machines to the high performance power profile. This has always worked for me, but not on this combination. I've switched it to balanced and it now steps down.
I'll probably install Process Lasso and use that to change the power profile when certain apps start.
Regards
Fred
