- 18 Feb 2007
- London
Hello
Early next year Im tempted to get a PC to replace my series x, I primarily play MSFS 2020 and now 2024 (the latter is a bit of a state though currently) and the odd exclusive like Indiana Jones.
I have a fairly large tv cabinet which comfortably fits my ps5 and series x with a lot space to spare still.
I have no idea if replacing my series x for a pc is a wise decision or not, I want it be a simple straight swap if you like, hooking up to my 55" LG CX via hdmi. In a way my series x feels like a PC as I use a mouse and flight stick with it to play msfs.
Im looking at the prebuilt options on OCUK but not sure what spec I need to run MSFS, also it will be used upstairs and my only option is wifi, so it needs to have solid wifi connectivity. Never had issues with wifi upstairs, just unsure how a desktop will do over wifi.
Budget is around £1500 give or take, and want something that I can upgrade when time comes if need be, presume all have the option to upgrade RAM, GPU.
Can anyone spec a pre built please from OCUK.
Thank you
Thank you
