- 25 Nov 2011
- The KOP
That is quite impressive! In that video, it wasn't till he said side by side did I notice the line down the middle of the screen. That in itself shows just how good RIS is.
It's also 3840 cores vs 2560
RDNA is a big improvement over GCN and a 40 cu part keeps up well.
Why do AMD insist on pants coolers for their gfx cards ?
I really wish amd and nvidia would both put the final nail in the coffin for blower coolers for gaming centric gpu's, all they do is hamper performance and cause headache.
The blower coolers are very bad because they are like magnets for disaster. Imagine what will happen with those 80-90°C when the dust bunnies gather between the small radiator's fins after several weeks of usage?!
I think this type of cooler is the critical minimum which they allow themselves to install.
They care only about their wellness and profit margins, but never honestly care about the customers.
What's the point of dozens of great features if your hardware design blows it all up?
I think everyone that are joining the cool club preoccupied with the idea in their heads of stomping AMD has forgotten that before the RTX cards came, all the Nvidia cards stock cooler was a blower cooler (though to be fair, the FE blower cooler could be mistaken to be styled after Apple product, who cares if the card is hitting 80C+ on thoseFair enough however this forum suffers from
double standards. 1080 series, Ti, Titan, Titan X and even the flipping Jedi Titan with glowing Leds which was lit up like a Christmas Tree and cost one squillion pounds - all blowers - £650, £850+
Wow great cards, Nvidia are king !
AMD puts one on their £350 reference card - Burn they at the stake!
Dual fan cards will come soon after launch, you pays your money.....
Nvidia's blower-style reference cards also throttled by default though. They were designed specifically to hit the temperature throttle point (84 degrees), then to lower clocks rather than increase fan speed further. That's also way hotter than I'd be comfortable running my card day to day, so increasing the fan speed from the stock curve is mandatory unless you want suppressed performance and temperatures in the mid-80s. Any acoustic advantage melts away at that point. Blowers are just inherently crap compared to open-style cards, bar niche use cases.The problem isn't the blower.
The problem is it's crap thermals and acoustics.
On Nvidia blowers such as the 1080 it had better acoustics than the 5700XT has etc.
If you're comparing reference cards, I'd agree. But IMO you should wait for the partner cards from both and see.This.
After watching several views, and reading reports.
RTX 2070 Super is my card of choice.
Not into loud AND +90C cards.
One is ok, but not both.
Just flicking through the reviews.
I know it is an edge case but it looks like the stock reference 5700XT just owned the 2080ti FE in Forza Horizon 4 1080p.
Somehow AMD fixed their poor 1080p performance for Navi.
@Martini1991 the 1080GTX Fe blower was quiet because it was one of the coolest running GPUs ever, if not the coolest. Great chip!
On what planet did the GTX 1080 FE run cool? Because it wasn't this one. It hit its thermal throttle point like every other Nvidia blower card, then tanked its clockspeed way, way down in order to stay there. Barely over 1600MHz, which is 300MHz+ less than what you can expect from a decent AIB model at stock settings (heck, my Palit Game Rock version hit 2GHz out of the box).@Martini1991 the 1080GTX Fe blower was quiet because it was one of the coolest running GPUs ever, if not the coolest. Great chip!
That's because the 1080FE's cooler had vapor chamber (same as the Titan's cooler), while the 1070 and cheaper FE cards got that gut ripped out of them.@Martini1991 the 1080GTX Fe blower was quiet because it was one of the coolest running GPUs ever, if not the coolest. Great chip!
Literally no one seem to remember the other FE cards's blower cooler had very average cooling capability, but they seem to get confused because it looked the same the Titan cooler. Even the 1080FE with the Vapor Chamber was struggle to keep the clock speed above 1900~2000MHz, where most other 3rd party cards with custom coolers had not problem keep it above 2000MHz+.
