- 4 Oct 2017
Anyone know what these will be retailing at?
£449.99 I reckon.
I was assuming £415 (MSRP of £345 + 20%).£449.99 I reckon.
I thought the 200W power draw was only under all core workloads that’s what I was led to believe.200 watts in some of those game for the 12900KS.
It looks like the last one sold in March for £380.I wish it was £350 lol.
I'm going to struggle to get much more than that for a 5950x.
For anyone with members market access how much are they going for on there now?
When TPU jumpted the reviews, I was surprised that on the apps side only really WinRAR performed much better. I do suspect that the build-in 7zip benchmark (easy to use) does not see any benefit because of the settings: default is a 32MB dictionary whereas for solid archives larger ones tend to get better results. Default 7z Ultra setting is to use a 64MB dictionary but the memory usage estimate is far above that:
I suspect to really take advantage of the huge cache will require developer work.
From the Phoronix reviews of Milan-X:
https://www.phoronix.com/scan.php?page=article&item=amd-epyc-7773x-linux&num=1
and the kernel 5.18 follow-up:
https://www.phoronix.com/scan.php?page=article&item=amd-milanx-linux518&num=1
The kernel made big difference. And while their reviews stick to their standard test suite, being able to re-compile (which I assume they do) makes a big difference.
Obviously, HPC workloads tend to be used to having to re-compile. Although even then I would think more can be squeezed out of certain workloads rather than just telling the compiler that the target has lots of cache.
Bethesda's Creation Engine will an interesting to see results, we just need a volunteer:
Will interested to see your results. I would also appreciate posting in @CAT-THE-FIFTH's FO4 benchmark thread:
https://forums.overclockers.co.uk/t...hmark-thread-need-some-zen3-results.18946938/
Yes, the power figures in the CB review are pretty telling. We all know the 12900KS is the Special-power-hug-Editon, but since 5800X3D uses less power than the 5800X due to the lower clocks, the 12900KS uses closer to three times the power:
https://www.computerbase.de/2022-04...2/#abschnitt_die_leistungsaufnahme_in_spielen
58W vs 151W is a very poor showing for Intel's KS model. And the extra 46W compared the normal 'K' gains them at most 3% at 720P (and even a regression in RT performance for whatever reason). Guess power usage is no longer important.
That 12900k power draw while gaming is exactly the same as my 5950x, high core CPUs pull a lot of power doesn't matter who it is
Your CPU should not be pulling more than the 5800X in those charts, it certainly should not be pulling more than 130 watts whatever its doing unless you overclocked it.
Why not? My 5950x also pulls similar power to the 12900k (although yes not over 130watt as it stock) but certainly similar figures.
Suicide run!I see some nutter has already pushed the X3D to 5.15GHz using BCLK (1.2v), that's gonna be some serious performance if it were stable for anything other than CPU-Z validation.
Suicide run!
There is a 142 watt limit on the socket, its should't be pulling more than that unless you have PBO set.Why not? My 5950x also pulls similar power to the 12900k (although yes not over 130watt as it stock) but certainly similar figures.
https://www.overclock.net/threads/5800x3d-owners.1798046/#post-28975536
Thread here with a guy testing stock vs oc'd 5800X3D including mem oc.
Not 5800X3D user here (just a 5800X), but testing this and it has been pretty good, finally an "official" AMD Auto curve optimizer.
