Yeah, Hardware Unboxed in a separate review compared power consumption and clock speed AIO vs Box cooler, on the AIO Ryzen used a little more power, and boosted higher, what a surprise that isn't to me.
Ryzen 3000 behaves a lot like Pascal GPU's, the cooler you can keep them the higher they clock themselves.
Look at those reviews i posted, 3600 under a proper cooler. 3600 @ <4.2Ghz 498 FPS, 9600K @ 4.3Ghz 423 FPS that's a difference of 18% to the 3600, side by side video runs don't lie like slides so easily can.
5% or so might not sound like a lot but where they are this close it maters.
https://www.techspot.com/review/1877-core-i9-9900k-vs-ryzen-9-3900x/
Because its a margin of error difference - an AIO water cooler is £40 to £60. What is the point when that adds,25% to 30% to the cost of a Ryzen 5 3600,and makes the difference between the Core i5 9600K(which can overclock more) less than £40?
This is what you are not getting,to get that Core i5 9600K to 5GHZ,it will be coming close to £270 to £290 including the cooling. A Ryzen 5 3600 is £190 with its stock cooling and HUB showed a Wraith Spire is good enough as an upgrade and can be bought for £5 if you want to get a minor increase and reduced temperatures.
I am running a Ryzen 5 2600 with the Wraith Spire cooler in a mini-ITX system. That cooler cost me £5 extra.
Also guess,what it made hardly any difference in actual boost frequencies using the crapper Wraith Stealth,it only ran hotter.
"Its not performing as well as it could with a proper cooler, but the point we want to make in this CPU performance review is its great value, AMD again with the lack of performance but hey ho at least they are cheap"
No, i'm sure AMD are sick of being seem as the "budget option" FFS let it stretch it's legs and put a proper cooler on it instead of strangling it and perpetuating the "budget plebeian option" that has plagued AMD for a decade.
No because in the end your view that AMD needs a £40 to £60 option favours Intel more.
You are literally making an excuse to favour Intel. If a AMD Ryzen 5 3600 can get 95% of its performance on basic cooling that is excellent,as it literally makes the Core i5 9600K look £80 to £100 more expensive for its 10% or however much its faster.
Once you ignore the stock cooling it drops the difference down much more to like under £40.
I am running a Wraith Spire on my own Ryzen 5 2600 in a mini-ITX system.
It works fine,and I don't give a damn if a £50 water cooler gives me another 100MHZ boost.
In fact its an advantage to me,to be able to do this since water coolers are bulky and I got fed up of having to use one on my IB Core i7.
DF are entirely correct to emphasis the extra cost of the cooling required for Intel CPUs.
Moreover,if there is a critcism,it is that I like to see Intel CPUs additionally tested on cheap cooler too,ie,a £20 cooler to see how they perform.
Equating cooling might add a bit more performance if you just want to compare CPUs,but trying to ignore it is not helping AMD at all.
For example a Ryzen 7 3700X is £320 including the boxed cooler. The cheapest Core i7 9700K is £369 with no cooler. If you add a £60 cooler to the Core i7 9700K,it comse to £429 which makes the difference £109. OTH,if you push to have AMD have the same cooler to gain 5% or less extra performance,the difference is under £50. Intel will still eek out a victory in those lightly threaded games like ARMA III and so on.
