Score update
6.453
Simply Awesome!
HiVizMan - What cooling you using?? I know one of your HWbot entries says Watercooling. You mind doing a quick rundown of spec?
I'm finding my water setup is temp limited when running vcore that high.
Well I "only" got to 5Ghz (only tried 5 for now!)
Bit of an error on my part in getting there though
I was trying to stabalise my 4.6 and changed a couple of settings. In the middle I thought what the hell, lets try 5, so I up the voltage to 1.42....
yes, thats right in image its showing 1.65what I actually did was put the voltage of my RAM to 1.42 and the CPU was on auto voltage
oh well, it ran, worked and then set back to 4.6 @ 1.37v to see if it stabalises overnight!
Surprised at your Super_Pi speed. Mine at 4.8 gets the million in 7.813.
