Dah, I want in this club...![]()
I'm too scared... I seem to have a pretty good chip but I think 4.8 is the maximum I'll chance. Might give it a go this weekend after writing down all my settings...
1.39 would login but bsod before I could run pi or cpuz and 1.85 would crash on the login screen. All of this at 5Ghz to find where to move up from.
whats there to chance?
if your chip goes pop then your still covered by intel....but it wont
ive had 1.6v through mine and its fine just got to keep temps down thats all.
what cooling do you have?
Actually I have xms3. It is currently at 1.5 but it was at 1.65 for ages so i'll just put it back to that. I just tried 1.5v on the vcore (nothing else changed) with 51 multi and it didn't post. I am finding it quite annoying that it seems luck of the draw each time it fails to post whether it decides to reset the settings or not. Sometimes I have to sit through 7/8 restarts before it will reset the settings and go back to UEFI.
can you link me that ram?
1.65v is to much for sandybridge
what error code do you get when it bsod
Silver Arrow. I'll have to ramp all my fans up though (they're all on minimum at the moment and my CPU isn't too bad while gaming - 69* max with fans on min under Intel Burn Test). I'm currently compromising on Noise/Performance.
is 69c when on 4.8ghz?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-290-CS&groupid=701&catid=8&subcat=1517
1.65 was its default value. I don't understand this at all. If my PC fails to post even once i.e. after turning on it just goes to a black screen it throws a hissy fit and won't post with anything but stock settings.
No. 4.6 under IBT (with all case fans on min... I can drop temps quite significantly if I ramp them all up but it then defeats the object of me building my system to be as quiet as posssible!)
MAN that way annoying. Took me about half an hour to get my PC to boot with an OC of any kind. It wouldn't accept either an automated 4Ghz OC or a Manual set 3.3Ghz (i.e. the stock speed) with 1.41 volts. It would only boot if it reset the settings after failing and I let it continue to boot from that rather than entering UEFI. In the end I reset UEFI to defaults and that seems to have done the trick. So... what the hell is my PC doing? Why must I reset it to defaults if it fails to POST even once?
As it is I can't really push my CPU if it keeps doing this. I can't spend half an hour inbetween voltage bumps.
my god dave beast 1.680v you really wanted to squeeze that oc out....
now time to hit the 55 multi![]()
