squeezed out slightly better super pi score on a 55 multi but not enough to take another place on the board
Well I have been fiddling with my OC. It was on Auto OC to 4.8 but was using too many volts. Currently running a manual OC to 5Ghz with speedstep on, using offset voltage so i'm not sure what volts to report.
Anyway...
Prime 95 will pull 1.352-1.368v.
its your ram mate.....
sell it and get some of this http://www.overclockers.co.uk/showproduct.php?prodid=MY-299-CS&groupid=701&catid=8&subcat=1517
it was good enough for my 5.4ghz clock on a 2600k currently in the top 20 and its only £44
This is a bit too slow really. I have a feeling it might be because the multiplier is bouncing between 55 and 16 before I start the run so doesn't begin at full speed. I can't find how to fix my multi at 55 though.
Better result with C3, C6 state, Speedstep, Spread Spectrum all disabled and a .1 bump to BCLK. (Still downlocks to 16x though).
My best time on a 2700K. I don't think I'm going to beat it now, I can no longer boot with the same settings and am not going to risk going over 1.6V even for a better benching run.
Well the 5488.4 post had Speedstep, Spread Spectrum, C3 & C6 all enabled so drew less. It is possible I didn't need them at all, I was just trying to get the multiplier to stay at 55 (or whatever I choose) all the time, but it seems I can't turn turbo off. I can try again with them all off and keeping the .1 BCLK bump.
Anyway...
