- 8 Oct 2011
- Lincolnshire
![85280059.png](http://img52.imageshack.us/img52/7640/85280059.png)
not quite sure what to do with memory timings will try again in a few days
Wish I could help think Iv been lucky with mine all Iv changed is the multiplier and volts o and set LLC to ultra high still hoping this gets updated really want my name on that list![]()
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.425v core voltage, doing so could limit lifespan of the CPU
- Aim to keep temperatures below 70c underload if at all possible
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Thought I'd have a little speed bump, now I've got better case fans in![]()
