[OcUK Staff Builds] Project Defiant
just my 2 cents about those Thermoelectric/Peltier Module thingy's.
A few years ago back in the gcse days my mate bought a couple for his project. The ones he got ran so hot that the wires fell off, and just generally fell part. Im sure they would have been improved since then (nearly 7-8 years ago), but deffo test them thoroughly.
Thanks for the heads up, going to build a test system first to use them in, then once it works correctly install it into my rig!
still no final pics of the system now?
There will be!! I just need to remeber to put the memory card in my Camera this time - spent ages taking loads of pictures of my system on a white background ETC then realised there wasnt a memory card in it! :mad:
Will take some before I take it all apart again!
This looks so cool, and neat lol. Ive only got a crappy H50 and my case looks very cramped compared.
Would love the money to do this (Or your job...)
ah i get it you basically want to use the TEC as a plate heat exchanger and the tec is really your chiller feeding that plate heat exchanger. why not just get a water chilling unit for a similar price range?
why does it say intel core i9? lol
