Updates!
Finally lost the Supreme FX board and the really annoying Blue LED'S that come along with it.
Now got a nice new Asus Zonar Essence STX which comes with the headphone AMP built in and I have to say that I am Blown away by the difference in sound. I always thought the Supreme FX was good but didnt realise that it could be bettered by such a large margin.
Plans on the Horizon - I have overclocked the system again and again and again. Now got it stable at 4.4Mhz with 1600Mhz on the memory, but temperatures just arent as low as I would like and my room is now like a sauna so back to the drawing board.
I have always liked the Idea of TEC's and have been facinated by how they function. There are several different ways that you can use them none of them are very asthetically pleasing so I plan to develop something else that will be (or at least I am going to try!). I am not looking to go silly with the temps here I am looking to reduce temps over the hole loop by 10-20degrees nothing ground breaking but enough to get a little more headroom for overclocking and stability
So the first major problem with TEC's is the pure amount of power that they need and consume to work effectively. The other problem with them is mounting them, there are two main ways that this can be done, you can use them as a sandwich between CPU and Waterblock/heatsink or you can mount them on a rad so it cools this directly.
I dont like the first method of mounting them as you have to pack the CPU socket full of Grease ETC
Like this
Which looks like a massive problem waiting to happen, the second option would be to mount the TEC's to my Rads and cool them directly unfortunately this would be an option if the bottom of my TJ wasn't already cramped.
So along comes option number 3 - Make a TEC waterblock to act as a small waterchiller. or at least thats the plan.
so after much reading it looks like this is a viable option. First off Need to find a PSU for it and it needs to be variable and meet the power ratings of the TEC's that I am going to use.
So I managed to find a Bench PSU that is Variable offering 15V at up to 30Amps which will therefore provide me with 450Watts of power at these ratings also with the added advantage that it is variable so when the extra cooling isnt needed it can be throttled down so I dont need to invest in E-ON Shares!
Although the PSU that I am looking at is an external one and has its own power switch ETC I want the unit to switch on when my computer does so I will need to wire in a relay into the mains power going to the unit for this I will be using a CRYDOM - D2425 - Solid State Panel Mount Relay
So the next thing I ideally need to find are some TEC's that I can power of this unit and Cool my system effectively. So I plan to use 4 of these
12711-5L31-06CQ Thermoelectric/Peltier Module
These should then when run at their maximum which is 15.2V @ 6Amps provide 51.4Watts of heat dissapation each giving me a total of around 205.6Watts total.
Now each of these has a Hot side and a Cold side for each of these I will be using a Waterblock, one to cool the components in the loop then another to mainain the temps on the hot side.
These are what I plan to use for this -
Then I will have to run Dual loops one to cool the TEC'S and one to cool the System itself.
I will post more when I start to gather parts and experiment with them.
