AWDFLASH.EXE m629b_14.bin /py /sn /cd /cp /cc
If you downloaded the bios file from abit there are a number of files in the archive. Copy them all onto the flash drive. One of them is a file called "runme.bat", this will start the flash process automatically. So, from the command prompt, which should be C:\> type "runme" and this should get it going.
That's the easiest way to do it. You can also run the awdflash program manually by typingCode:AWDFLASH.EXE m629b_14.bin /py /sn /cd /cp /cc
There are more switches that you can use but these are the ones recommended by abit.
Good luck with the flash, from DOS it is 99.9% reliable, can never rule out a power failure
BTW to get the pc to boot from the flash drive, all you have to do is change the hard disk boot priority to use the USB drive first. You don't boot from "other devices". The pen drive is treated as a hard drive, at least it is on my machine.
You will also need abitfae.bat, this file is called by runme.bat
(Just to clarify the actual runme file is labeled runme, not runme.bat, so should I just rename it autoexec and not autoexec.bat?
Upped the RAM voltage to 2.1v. The beast lives.
You, sire, are a God among men
Excellent review of the Abit IP35-Pro @ Anandtech CLICK HERE
One thing that put a really big smile on my face was that the Abit IP35-PRO got the GOLD Award.
The DFI UT P35-T2R got the Silver Award. Aww what a shame. . .
Cool! Do you have it running at it's specification? 500mhz @ 4-4-4-12 ?
I would have loved to have tried the DFI UT P35-T2R, like I mentioned on the errrr'm "other" forum we use lol, it's not very cost effective for me going from P35 to P35 it wouldnt be very sensible either , if both boards had been released at the same time, I would have probally gone for the DFI board & to be honest I'm quite surprised that the Abit board was given a better award, I think it was mainly down to price costs than overall performance comparisons - I guess the Abit board represents good value for money not sure really.The IP35-Pro is a good board, I've recommended it a few times to people due to it being a P35 board, with a great layout. The Asus P35 boards (I would list, but Asus being Asus - I would be here all day), DFI LP P35-T2R, IP35-Pro and Gigabyte boards seem to be very peg level, each with their strong points.
For instance Mr Key says the IP35-Pro has worst vdroop out of all he's tested P35 wise, but offers a good all round package especially with uGuru. Once my radiator brackets arrive for my water cooling, I'll post a thread about the DFI board and how I've found it.
