Hi
Just got this mobo. Some questions if I may:
1) My PSU has a 24 pin and a 4 pin connector. The 24 pin nicely fills all the holes. The 4 pin leaves 4 holes empty. The manual says this is ok, but recommends 8 pins to 'meet the 240VA protection limits'. What does that mean exactly, and is there any problem me just leaving the 4 pin in?
2) Another power question: Do I need to connect the 12V auxilary?
3) I have a Tagan modular 580W - will that be sufficient for a single HD, optical drive, and a single 2900 pro? What if I add 2 or 3 drives?
4) I have got my first SATA optical drive (as supposed to IDE). I have plugged in the HD into Sata 1, and the optical drive to sata 2. Is that ok? What happens if I want to add say 2 or 3 drives in raid? Would it be ok do add them to 3, 4, & 5, and just raid those 3 together, while keeping the single boot HD and optical drive on 1 & 2?
5) Another SATA q - why, on boot up, does it list the sata ports in the order 1,4,2,5,3,6 ? (rather than just 1,2,3,4,5,6)
6) What's the recommended BIOS version? Just the latest?
7) Any tips or gotchas I should be aware of?
Thanks
Marcos
