No they don't. Not too sure if we're allowed to name name but there's a well known auction site which sells them.
Besty, could you explain re the bug for my benefit too? I'm experiencing a problem - when waking my computer from "sleep" mode the display doesn't come back on. I have to switch it off and back on, at which point it "resumes" but functions slowly. I thought it might be to do with Trixx. Any help appreciated!!
If it's the i5 I buy, will a second 5850 extreme in crossfire be a good purchase to see dramatic fps improvement?
Voltage only affects the core clock afaik, so leave the memory at stock speeds until you get the most from the gpu, then slowly start to raise it.
I take it you hit apply after changing the gpu voltage & saved the profile ?
yep then tested it using bfbc2 and msi after burner and it instantally crashes both msi afterburner and gpuz says it is running at 850/1150 but only at 1.088 v :/
Although GPUz displays 1.088v, it uses the voltage you specified in Trixx; I know because I get the same readings, but I was able to OC up to 920-940/1225 @1.225v so far. You should probably try with more voltage, say 1.200-1.250v which is a safe max and then slowly raise the core clock.
nope no luck took it to 1.125 (850mhz core) and still crashes not gonna go anyhigher just in case
what ccc version are you using?
Yesterday I installed the latest Cat 11.5a (with hotfix) from here: http://support.amd.com/us/kbarticles/Pages/AMDCatalyst115ahotfix.aspx
I would suggest you to lower the memory at stock speed and try to upper only the core clock in order to find the max possible..make sure you use at least 1.2v. I managed to get 825/1225 with my card at stock voltage, but not every card is the same and as far as I remember @1.15v I didn't get much of increase at the core clock; I think up to 1.25v is safe to go with the 5850, providing it doesn't get too hot for a long period of time (over 80-85°C).
Just played a couple of hours on crysis. (maxed with 4AA at 1680*1050 by the way!) and I've got a max temp on the 2 cards of 63C each. Is this strangely low or do these cards actually run very cool?
This is about the same temp my 5770 ran at but with these being more powerful cards and being so close to each other, I was expecting higher. Idle temps of 35-40 now.
