I'm up to 925 core on 1.25v
If you got a good CPU cooler, your board should be able to clock your E7200 up to 3.8-4.0GHz...which WILL give you a couple more fps in Crysis.925/1200 @ 1.23... However I seem to be bottlenecked by my E7200 @ 3.35 - anyone have something similar? Uniengine score went up with the OC, but not Crysis. Notching the CPU up to 3.41 got a couple more fps in Crysis...
@925/1200, uniengine score is 1011 with those parameters, except my display is 1400x900.
@stock, score is 823.
sHo0sH, 10 mins of furmark doesn't seem to cut it for me - mine was stable for 20mins and then crashed in uniengine.
I did the same test procedure, first Furmark run for 20mins at least then looping Unigine Heaven for half an hour. Doing so I reached stable 940/1225 @1.225v, but when I started testing the OC in games such as Crysis, NFS Shift and Mass Effect it crashed after some time. It seems that Furmark and U.Heaven only aren't enough to test if the OC is stable. I had to lower the core at 920 to get it stable in gaming.
Thanatos, seeing as you've got a C2D @ 3.2 was wondering if you saw any increase in scores/frames thru oc'ing the card? If my experience isn't anomalous somehow you should be bottle-necked by your cpu...
Question for when my 2 5850s come:
Is the correct procedure to install the cards:
remove drivers of old card > remove old card > fit both cards in > install crossfire bridge on them > boot up the pc and install the latest drivers from the amd site
Which drivers do I use? I've seen a few posts where people talk about application profiles and that?
There is a 2D Power saving bug in the drivers/BIOS which prevents this card from working in my PC at stock settings, which is reproducable.
The bug is reproducable with Cat 10.10e and 11.4.
I got around it by placing a 3d application into my start folder, minimising it and overclocking the card (sic), giving it some extra voltage in the process, using the Sapphire utility. Stable as a rock so far.
So after a run at 900/1200 I am getting a Unigine score of 878, average of 34.9 fps min 18.1 fps and max 85.4
Anyone else care to share their findings?
