p5k-e Q6600 OC Help please
*warning*
overclocking is adictive
*warning*
should come on those G0 CPUs :)
totaly off topic but you will like this one CyZMyAssBaby got my brothers new G0 to boot @ 4.3Ghz this afternoon :) is going to be a monster... but will have to wait for next weekend cause am off on holiday tomorrow... almost dont want to go now and sit and play with the new CPU instead :)
*warning*
*warning*
CANCEL THE HOLIDAY OVER CLOCKING IS A PRIORITY & SUPERSEDES ALL OTHER TASKS REQUIRED OF YOU. END OF:p
:DExcellent over clock M8 temps, voltages ect.:D
well didnt prime @ 4.3 but only took 1.55 BIOS Vcore to boot, it was prime stable for a good 2 hours @ 3.825 @ 1.425 load vcore :) temps a little high but am yet to lap his ultra120 or CPU so will sort that, I was only there this afternoon so had to get him a stable setup so not much time for playing around :) but next weekend will get stuck in and post some pics
Nice one m8. OEM or retail out of interest
Could do with some help guys, went to 3.6 got into windows and then got a BSOD, clocked it back to 3.4 and 3.2 but after post all I'm getting is a black screen where windows would normally load :(
Changed all settings back to default and still nothing is my windows install borked?
edit - I'm guessing it is as my XP disc loads up fine, going to try a repair first then a complete install if I get no joy....argh!
ok doing that now...
My heads in the bin today! Fired the PC back up after clearing the cmos...nothing on the display, thought oh cack I've killed my gfx card, yup you guessed it forgot to plug the power back into it lmao.
Going to clock back to 3.4 and leave it today I think!
Cheers for the help CyZMyAssBaby, will be back tomorrow for >3.4 :D
Tried for 3.6 again and managed to get into windows with CPU volts at 1.4125 in bios but failed primed, increased this to 1.4250 and again failed prime, increased to 1.45 and got a BSOD as soon as windows loaded. So I'm back at 3.4Ghz >8hours prime stable, I think I might have found the limit of this chip?
bumpy :D
Any further advice on getting to the elusive 3.6Ghz guys as I cant seem to get to 3.6 without BSOD's but at least it does load windows :D
Nice O/C and temps sepulchre:)
not sure, but I'll look tonight when I get home from work, what's a good value to set if I do?
The PLL voltage is a key voltage to maintaining a stable FSB, will post link and info if can find it amongst my disorganized bookmarks. The original info came from extreme systems forums. W3bbo also posted about PLL on the forum not so long ago. The range used 1.5-1.7v. Although a sensible approch would be required ie a notch at a time. You can also raise your NB a notch and see if that offers stability.
OK, will give that a try, daft thing is when these are set to auto finding the actual voltage the board is using seems almost impossible, or am i missing something?
