p5k-e Q6600 OC Help please
Bought on required features, and cost, for silent HTPC and PC duties.
9designs2 some info for you
Gigabyte GA-G33M-DS2R Micro ATX (Socket 775) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-091-GI&groupid=701&catid=5&subcat=
Bargin
further info/ review testing with a
Wolfdale E8500
580.5MHz max FSB with E8500 Wolfdale on (HTPC)using a Gigabyte GA-G33M-DS2R
CPU is Aircooled with an Freezer 7 Pro
Mainboard is stock without mods.
http://www.xtremesystems.org/forums/showthread.php?t=168399
To get those numbers is off the chip it's self yes ?
Well order was late on the Friday 21st as I waiting for the case to come in stock, order placed at 15.19, dispatched at 17.14.... Way to go OcUK !!!
So I could have a monster chip !!!!........****** if I had known I would have bought a better board !!! aahhhhhh........... I really don't NEED to overclock, but now you guys are making it way too tempting and ADDITIVE !!!! LOL
Only started because in single thread apps, it doesn't feel any quicker than my old P4-3.4 !!! ....... So wanted to get to 3.4 ...
Anyway for ref
I wish I'd been fortunate enough to pick up a low VID chip.....sniff lol
Meant to add this earlier :)
That is still an excellent O/C 3.5Ghz and excellent temps:) vid at (1.3125v) under prime CPUZ @1.376v. That chip has potential even more if it were lapped;) The mother board could be holding the OC back
Some amazing O/C here !!! ................... Just looking at the mobo page for replacement boards!!! .........hate you lot ! ;)
Found it's not Possible to turn off speed step !..... even when you disable in the bios and set a fixed 9 multiplier, it still sits at 6 when idle, according to CPUZ..... :(
The ASUS windows o/c software crash as 2.5 !!! LOL
9designs2 you may find this information useful
GA-G33M-DS2R review
http://www.ocworkbench.com/2007/gigabyte/GA-G33M-DS2R/g1.htm
Supports Intel Core 2 multi-core and upcoming 45nm processors
-Dual Channel DDR2 800 for outstanding system performance
-Integrated Intel Graphics Media Accelerator 3100 (Intel GMA 3100)
-Integrated SATA 3Gb/s with RAID function
-Features high speed Gigabit Ethernet and IEEE1394
-Integrated ALC889A 8-Channel High Definition audio
-Ultra durable2 motherboard with top quality highly efficient components
A Look at the Bios ;)
http://forums.vr-zone.com/showthread.php?t=150924
Yeah I looked up from your earlier post, BUT, no SPDIF socket,..(needs to be bit perfect) so will need Sound card, which I have, but limited PCI sockets. Have TV card and CAM holder plus Sound card, plus will need second LAN card in the future to hook up to LINN type "squeeze box" ...Unless I buy a NAS from the outset.
So I don't think it has the room or the options....shame.
Might have to be the PK5-E wifi popular in this thread !!!!
I see with the information you have provided i think i will start a learning curve with HPTC systems and associated MBs
A nice mother board, would you stream between the HPTC and this board? The wireless feature as well OC as a bonus
this sounds crazy, but 3.5 on a 9x multi feels slower in games than 3.4 on an 8x multi, would the higher fsb be better for gaming?
lol, with the number of reboots I've had between trying to sort out my front panel audio connectors no... cant seem to get my mic and headphone socket to work under vista, works fine under XP ??
Whats the diff between higher multi and higher fsb btw. If you achieve the same clock with lower multi/high fsb and high multi/low fsb does one perform better than the other? which is the preferred and why please?
As I understand it (and this is especially true of data hungry quads) if you achieve the same clock frequency then using a lower multi and higher FSB is preferable to a higher multi and lower FSB in performance terms as there is more data travelling to the processor across the fsb, although this does put more strain on the motherboard. Having said all that I could well be wrong :D
I would say it depends on how tight you can keep your RAM timmings, generally higher FSB will give you more performance but you shouldnt sacrifice running you RAM slower to achieve this.. for example FSB 400 * 9 and RAM @ 4-4-4-12 is going to be better than 450 * 8 and RAM @ 5-5-5-15
