- 17 Aug 2007
- London, Moscow & Samara
3.4 if you please lmao
I quite agree, I think I'll stick with this at 3.4 as it seems quite happy there and also very quiet. Many thanks for your continued help though!!!
Wonder why that was then? There is no reason that I am aware of where you can't overclock a chip using stock multi but can overclock it if you drop the multi?I'll try the 9x multi again, but (and this may be down to me being new to C2D clocking) I couldn't get it to work when trying any variation of OC with the 9x multi when I first started out.
Thats weird also?Mine will only post if i put both sticks in the top two slots, one yellow one black.
thats loads, hmmm.Yea its at 1.55 atm
is that at any speed or just high FSB?Mine will only post if i put both sticks in the top two slots, one yellow one black
Hey there, i have the exact same setup as you, great minds and all that. Have you tried running 440mhz fsb?
Have you got your ram to boot in dual channel?
Sorry for the thread hijack, will try and keep it to a minimumthats loads, hmmm.
sepulchre if you drop your multi to x6 and test to find the motheboards max FSB. (Save all your previous OC settings in the OC profile) and start the OC fresh using the x6 multi
can you post back your findings m8
