how exactly do you do that?
how do you drain the water out of it, because you just cant unplugged all the hose out as it will drip onto your component,
sorry if it sounds nooby but i just started looking at watercooling
In my rig I pull one of the hoses off of the radiator as the base of it is the lowest point of my system and allows a quick drain.
