Pearleasnt Liquid cooling mix
I was just looking at these phobya res' wondering if you can fit 3/4od compressions on them with no clearance issues like i have on my ek multi res 250?
So im no longer goona now mess with the colouring -
I have the final five colours which im happy with. I know some people would like Red but im not happy with it so until its perfected which it is not ill keep with what works best. I wont release any thing i think is not up to standard.
Below are REAL photos, no adjustments, no colour changing, no bringing or any thing. All so the names they will be called.
Mayhems Aurora - Nebula Blue
Mayhems Aurora - Galaxy Purple
Mayhems Aurora - Gemini Pink
Mayhems Aurora - Supernova Clear
Mayhems Aurora - Extinction Green
All we need now is testing and results ....
Wow, really looking nice now, makes me want to put in clear tubing and use this stuff, really like the purple.
So how long before it becomes available to buy?
this morning i received the full RASA kit from XSPC.
thank you Paul over at XSPC for sending us the kit to add to out tests.
Once it was fitted in to a older chassis we started running test and found that the viscosity of the liquid was to much how ever like all mad men we have a back up plan and changed the ratio of the liquid a little.
With the new adjusted liquid every thing run fine and we even got a 4c drop in temps.
Some quick pics of the liquid in action with the RASA kit from XSPC
Rasa 750 RS240 WaterCooling Kit
Video will come later
That looks awesome! Seriously! Can you make a version with suspended UV reactive particles, so only some of the particles glow, and not all? Is it even possible?
well ive got one that heat sensitive. How ever thats a long way off being finished
these were done this morning with it just as a quick test -> Red hot / Blue cold
Have you done any temp comparisons?
He has posted some on another forum & says that he is trying to improve the temps.
Are temperatures affected by the liquid?
The short answer to this question is yes. In testing we found due to the viscosity of the liquid the temperatures may increase from 2 to 5c (this is in comparison to Mayhems Ultra Pure H20) depending on your set up. We are still working on getting this information correct and are working with independent testers so that we can gather and correlate as much information together possible. This will give you a fair understanding on what temperature difference you may see.
Its 3c above water confirmed from independents yesterday.
how ever tests are still on going.
Testing Results :
Cooling bocks that have impingement ports are not recommend for use with this Product. If the block has a plate and it is removable then we advise that the plate be removed before proceeding to use this liquid.
Water Cooling Blocks and parts
XSPC
RASA water block - PASS
RS240 - PASS
X20 750 Pump & Reservoir combo - FAIL ***
Single Slot Pump & Reservoir combo - FAIL ***
Laing DDC 200ml Reservoir Pump Top : Plexi - PASS
Single 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Duel 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Standing for 1 week - Working
Constant flow low rate - Working
Constant flow fast rate - Working
Long term testing - On going
Temperature + 2.5 to 3c (stress testing under Prime 95) after 7 days of running.
(no build up in block found)
*** Bay reservoirs with pump cause build up between the pump and the reservoir were the liquid is standing and there is no flow.
Watercool
Heat Killer
With Restriction Plate - FAIL
Standing for 1 week - Fail
Constant flow fast rate - Fail
Temperature + 8 to 10c
Long term Testing - Fail
(Build up in block found)
With out Restriction Plate - PASS
Temperature + 2.8 to 4c
(No Build up in block found)
EK
Supreme LT AMD Acetal AMR3 - PASS
Temperature + 3.1 to 4.3c
Long term testing - on going
Supreme HF - Under test (new plating) extra checking to see if fluids ruin the coating
FC460 GTX (old plating) extra checking to see if fluids ruin the coating
Phobya
DC12-400 12 Volt Pump - PASS
DC12-800 12 Volt Pump - PASS very hight flow rate - looks like liquid is on acid .....
Balancer 150 Black Nickel - PASS -=Out standing effect's=-
S.1366 / 1156 Water Block - PASS
G-Changer 240 - PASS
Swiftech
Apogee XTL (will not be testing)
Apogee XT Extreme (will not be testing)
Koolance To be tested (on site not tested yet)
Koolance CPU-370
Laing
DDC 10 watt (working)
DDC 12 Watt (working)
D5 (not tested)
