- 10 Oct 2006
As the owner of a Mondeo 2.2 TDCi and having done 21k since I got the car, using only supermarket fuel & the occasional bottle of diesel cleaner (Redex etc) I can tell you that my EGR is almost clean too as I changed all my boost pipes for silicone ones recently. EGRs clean themselves provided you drive the car right meaning it gets hot enough to burn the crap off of itself. Blasting down the motorway for about 20mins @ 70mph will do just that.
It will be the redex cleaner that is helping your's, they certainly don't keep themselves clean even if driven fairly hard I've helped swap a few and they are normally a mess inside.
I've thought about trying a bottle of additives instead of the odd few tanks of BP Ultimate or V Power diesel but don't want to risk the warranty on the car when it says add no additives on the filler cap.
) on my 996 turbo. I run my M3 on vpower too, just go with whats on the cap as thats whats its optimised for, i suspect if it says 95 on there, premium will make no difference (happy to be proved wrong on this however).
